Question about Brother MFC 210C All-In-One InkJet Printer
Brother mfc215c ink problem
How do I do a print head realignment please?
  • geritwo Mar 24, 2008
    Thank you. I was actually going to try a 'fix' that you had suggested for someone whose brother kept saying 'ink empty' or 'no cartridge'. Mine is doing this even though I have put new full catridges in. I have tried turning it off and on, taking them out, putting them back in, to no avail. Seems like it is in a loop. Have tried uninstalling, reinstalling but no good. Still the same messages. Think it needs to go back to factory settings, but don't know how to do it. Any ideas?
  • 667 Answers
Here is a link for your manual. You want section 12 page 18. If your printed pages are distorted you may want to check the pages on cleaning your printheads. If you need more help just add a comment and I'll be glad to come back and assist you.
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000453/BH3eLowBase_AsaOceEngUsr.pdf
Posted on Mar 23, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 27, 2008
    I apologize for not gettng back to you. The system has a kink and sometimes we don't get notified by email there is a comment for a while. Just happened to be checking my solutions that had no ratimgs and saw your comment. You'd be surprised how many people don't rate a solution when we fix them. Anyhow, did you happen to notice after you put the catridge(s) in the first time what the lcd display read? Or is this where it started saying the ink's empty? It should've read something like " new black cartridge - 1 for yes 2 for no ". Did you ever get to that point? If you can remember, tell me exact sequence of events. I know you basically have just bare with me. Add your comment and I'll keep checking for it. Thx.
SOURCE:
The black will not print. I have replaced the cartridge with two new ones. Color prints ok. Brother mfc 5840cn
please perform head cleaning to see if there is any ink out.. goto ink management and select head cleaning... after that goto ink management and print the nozzle check.. see if there is any black ink out...if no ink out..then more probably your print head is badly clogged..and you will need to get it replaced.
Jun 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
I have a brother MFC215c printer, and it continues to show on SCD unable to print. Nothing in the manual is helping
This is some times when it says unable print it some thing sticking so the heads cant move easy.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 16, 2010 | Brother MFC-5440CN All-In-One InkJet...
Printer is Brother MFC215C. Cyan colour not coming
  1. Press Ink or Ink Management key on the control panel of the machine.
  2. Press 1 to choose 1.CLEANING.
  3. Press the up or down navigation key to choose the Black, Color or All you want to clean, and then press Menu/Set or Set.
The machine will clean the print head automatically. When cleaning is finished, the machine will go back online automatically.
Note If you clean the print head at least five times and the print has not improved, please contact Brother Customer Service from "Contact Us".
Feb 15, 2010 | Brother Multi-Function Center® MFC-215C...
Printer is saying unable to clean model mfc215c
If you look at the Brother website, you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the print head is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck peice of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code soemwhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Nov 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean on mfc215c
PAPER JAMED IN MACHINE PROBALLY ON THE OTHER SIDE OF THE PRINTHEAD SO MOVE THE PRINT HEAD ACROSS AND LOOK IN THERE FOR A PIECE OF PAPER PROBALLY SOAKED IN INK, HAVE A GOOD LOOK WERE THE PURGE UNIT IS MAKE SURE NO PAPER THER .
Or
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error, not worth a cracker, replace machine.
press stop to exit if needed
Thanks.
Dec 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
1.unable to clean?mfc215c
press stop to exit if needed.....
OR
Thanks.
Brother mfc215c cartridge problem
Sorry to hear that. Brother's have alot of problems with this sort of thing. Just so you know, I even called Brother and they said you're model printer didn't exist. What a joke. I said if it doesn't exist then how come I'm looking at a manual on my screen as we speak for that model printer that I downloaded from their site. They still told me it doesn't exist. I said then maybe we're not really talking on the phone! Again, sorry about the printer. If you have any other problems or just need advice feel free to ask. That's why I'm here. Just for you! How about giving me a 4 fix ya rating for old time sake? Give a shout if you need anything.
Mar 28, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc215c
press ink then set then arrow down til alignment. press start bk-copy. compare the print and set the numbers.
Mar 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
147 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
