Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
I need to rinse out my drip tray and dont know how to get it out
Its bolted in and seem that i need to get underneath the fridge to take it out....how can that be? can anyone help me??
    Scholar:
  • 126 Answers
THEY ARE NO LONGER REMOVABLE BY THE CONSUMER. THATS TO KEEP THEM FROM BREAKING AND GETTLING LOST.
Posted on Apr 24, 2010
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Our fridge is leaking water to the bottom - there is no water in the drip tray just on the bottom shelf - it seems to be coming from up above and dripping down the back on the inside. Any help
Clean drain starting underneath freezer coils. Compressed air is best but you can use hot water and blow in a tube until it is clear
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Maytag Refrigerators
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Odor
Sorry I don't know this model, so I can only give generic advice on this one.
Most fridges have the cooling plate at the back. Try to keep food away from it, otherwise ice will form on it.
At the bottom of this area there will be a gully and drain hole through to the back. Any drips that form at the back, will drip into this gully, go through the hole, down a pipe and onto an evaperator tray sitting on top of the compressor.
What usually happens is that dust or labels get stuck to the cooling plate at the back, which drips down, blocking the pipe, which then stagnates into a grey stinky soup.....Lovely!
What you need to do is defrost the fridge, spray clean the inside with a multi-surface cleaner, and flush this tube with the cleaner water. A turkey baster syringe may be the easiest way to do this. As the evaperator tray only holds about 1/2 a cupful - don't overdo it.
While you are there, clean the door seals.& dry the interior.
This should cure the problem.
Thank you for using Fixya!
Jun 14, 2008 | Whirlpool GD2SHGX Refrigerator
Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Mar 10, 2008 | Refrigerators
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
