Question about Magicard Rio Card Printer
1) it accepts a cleaning card but will not eject it 2) the print is randomly poor, as if one of the 4 colours has missed in parts or the ribbon is tangled
    Genius:
  • 1,354 Answers
Evolis pebble 4 shows the end of ribbon light...
Not card, not ribbon, not cleaning, not driver setting.
Does your black ribbon roll and never stops?
Sep 10, 2012 | Evolis PEBBLE 4 Led Card Printer
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    I have a datacard SP35 printer. I recently changed the ribbon and cleaned the machine. Now the cards are printing however they are only prining all yellow, all pink, all blue, black only, or half pink...
    I'm having a similar problem, except some of them randomly print correctly too. Let me know what you find out. Thanks, Glenn greiner@unionchapel.com
    Apr 15, 2011 | Datacard SP35 Printer
    Card jams and ribbon keeps breaking
    CLEANING THE INSIDE OF THE PRINTER
    As you use your printer, dust and other foreign particles may accumulate inside
    the printer?s case. These particles are attracted to the underside of the ribbon by
    static produced during printing and can cause voids on the printed image.
    Periodically, use the following procedure to remove dust and other foreign
    particles:
    1. Open the printer?s Top Covers.
    2. Remove the ribbon and overlaminate from the printer.
    3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
    slightly moistened with isopropyl alcohol to wipe out all visible areas inside
    the printer. Remove any debris that may be inside. Be extremely careful not to
    let any alcohol drip inside the printer!
    4. Once the cleaned areas are completely dry and free of foreign debris, re-install
    the ribbon and overlaminate, and close the covers.
    F. CLEARING A CARD JAM
    If a card becomes jammed inside the printer, the LCD Display will indicate
    approximately where it is jammed. At this point you can either try to correct the
    problem and continue printing with the same card, or remove the card completely
    and continue printing with a new card. Refer to the following steps for instructions
    on doing either:
    1. Leave the power ON, and open of the printer?s Top Covers.
    2. Remove the ribbon and overlaminate as needed.
    3. If you would like to try to correct the problem and continue printing with
    the same card, do so by pressing the On/Cancel button to advance the card or
    the Pause/Resume button to reverse the card. Use these buttons to help free the
    card from its jam. Try not to move the card too far from where it was just
    before the jam occurred. Once the jam is cleared, replace media, close the Top
    Cover(s), and press the Pause/Resume button to resume printing.
    4. If you would like to remove the jammed card completely, do so by using the
    On/Cancel and Pause/Resume buttons to manually eject the card. Then,
    replace media, close the Top Covers, and press the On/Cancel button. At this
    point, the LCD Display will prompt you to either press the Pause/Resume
    button or the On/Cancel button. Pressing the Pause/Resume button will cause
    the printer to feed in a new card and reprint the job which originally jammed
    along with all subsequent jobs still being sent. Pressing the On/Cancel button
    will reboot the printer and cancel all jobs within the printer?s memory. In this
    case, you must also cancel and resend the print jobs from your computer.
    Section 7: Maintenance 53
    Pro-L Card Printer User?s Manual
    G. CLEARING A RIBBON OR OVERLAMINATE JAM
    If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
    the LCD Display will indicate that it is jammed. Refer to the following steps to clear
    the jam:
    1. Leave the power ON, and open the printer?s Top Covers as necessary.
    2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
    from in between the two black Drive Hubs.
    3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
    to a card, pull the ribbon or overlaminate off the card and throw the card away.
    If it is jammed underneath the rollers, press and hold down the printer?s
    Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
    not **** the ribbon or overlaminate to free it, since this will increase the chance
    of breaking it. If it does happen to break, simply tape the broken end of the
    supply roll directly onto the take-up roll. Then, wind a few inches worth of
    ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
    ribbon or overlaminate is passing beneath both the supply and take-up rolls.
    4. Once the jam is cleared, replace media, close the Top Covers, and press the
    On/Cancel button. At this point, the LCD Display will prompt you to either
    press the Pause/Resume button or the On/Cancel button. Pressing the
    Pause/Resume button will cause the printer to feed in a new card and reprint
    the job which originally jammed along with all subsequent jobs still being sent.
    Pressing the On/Cancel button will reboot the printer and cancel all jobs
    within the printer?s memory. In this case, you must also cancel and resend the
    H. CLEANING THE CARD FEED ROLLERS
    To assure consistent printer operation, all of the gray card feed rollers within the
    printer should be cleaned during every ribbon change (every 250 prints) or if the
    rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
    Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
    Cleaning Card through your printer:
    1. Open the Top Covers and remove all print supplies from the printer. Leave the
    printer power ON and the Top Covers open throughout this procedure. The
    Cleaning Roller Assembly can also remain within the printer during this
    cleaning process.
    2. Remove the Cleaning Card?s adhesive backing paper.
    Nov 12, 2010 | Fargo Pro L ID Thermal Printer
    Displays colour streaks (mainly red)when printing
    you need to make adjustments in the driver control panel color options, you may need service to calibrate the temperature, this can also be a result of poor quality PVC cards. Some card design software will allow you print parts of the card with black panel only which would eliminate this issue.
    Mar 08, 2010 | Datacard Group SP35 Card Printer
    My printer displays ribbon error. but there is ribbon inside
    you can change which ribbon type is installed in the printing preferences of the printer driver.
    make sure you have the right ribbon type selected.
    CYMTKO vs. CYMTO, etc.
    There is also a button that will auto detect the ribbon right underneath the pulldown menu.
    May 26, 2009 | Fargo DTC550 Thermal Card Printer
    Ribbon is breaking constantly in every print of card
    in order of most likely
    1 edge to edge settings in printer tool box are off.
    2. print ribbon carriage (blue part you put the ribbon on is bad)
    3. Bad ribbon
    4. dealer needs to service to calibrate print head temp
    tulsabiz.net for more info
    Mar 27, 2009 | Datacard SP35 Printer
    Card printer is not printing in colour
    You have probably bought fake color ribbons , or you have taqken of the blue cup with the rfid inside.. Wich tells the printer what kind of ribbon installed
    Nov 19, 2008 | Datacard SP35 Printer
    Evolis pebble 3 ribbon problem
    Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
    Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
    Dell 922 black printout problem
    you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
    Remove the ink carts.
    on either side of the carrage there is a screw, remove both of them.
    CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
    also carefully remove the silver "fingers".
    remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
    lift the head (you see 4 nipples in there-- that is the top of the head assembly)
    gently pull out the ribbon cables.
    on the bottom of the head is 2 screws, remove them
    now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
    get some windex with amonia.
    soak the parts for a day or 2.
    blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
    reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
    this works 90% of the time
    Feb 09, 2008 | Dell 922 All-In-One InkJet Printer
    Magicard Rio Card Printer Logo
    41 people viewed this question
    Top Magicard Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
