Question about Samsung PN58B860 58 in. HDTV Plasma TV
Plasma tv showing "Mode not supported" message
I have a Samsung PN58B860 TV, and I have both a Blu-ray and High Def dvd players, but when I try to play a hi-def movie, it says "Mode not supported". I have all three devices, cable box, blu-ray player, and hd dvd player, going through a Psyclone video switch. This is how I had it hooked to my last plasma TV and everything worked fine. They all go to the switch through an HDMI cable and then one HDMI goes from that switch to the TV. I have tried swapping the HDMI from the HD player into the Blu-Ray player’s port and it still doesn’t recognize it. I am not sure how to get the TV to recognize the HD DVD player. What do I need to do for make it pick up the signal? Thank you
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Posted on Apr 26, 2010
  • Anonymous Apr 28, 2010
    i would also add that i already received a service call aftrer issolating clients switcher and replacing hdmi cable problem was solved his blur ray image appered ps its inportant with bluray to put a high transfer rate gable 10 gbs and more
Samsung Plasma PN58B860 works fine for about an hour that a yellow error message "Not Available" shows up in the center of the screen and won't go away or allow power off without unplugging the TV.
Do you have a program preview button i.e. one that shows details of current program and the following program. When the message appears try hitting that preview button.
Nov 04, 2015 | Samsung PN58B860 58 in. HDTV Plasma TV
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
How do I connect the DVD player to a Panasonic High Def Plasma TV?
Choose connections on the Panasonic that match those on the player--
Do you have on the player Component outs(blue,green,red and 2 audio which are red and white? This ought to give you the best picture and sound.
Other inputs to the set must match the ones coming from the player--Most owner manuals have a lot of details here.
If the player has 1080 output hook to a similar input on the set.
Some advice here: make the connections between units with both turned off.
Apr 03, 2012 | Durabrand DVD-1002 DVD Player
I recently bought a Sony Blu-Ray BDP-S370. The issue I have is that it will not play any DVD's on my Samsung HD TV The message "Mode not supported keeps coming up" Thanks
When you see "Mode Not Supported," hold down the "stop" button on the Bluray player for about 15 seconds and release it. This should reset the player to the lowest resolution over HDMI.
Check other Bluray player settings such as deep color, resolution etc. for conflicts.
Mar 14, 2011 | Sony BDP-S350 Blu-Ray Player
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
Does not have 1080p
You need a high definition signal aka high def cable, blu-ray dvd player etc...If you don't use a HD source you will not be watching HD.
May 28, 2010 | Samsung 58" 1080p Flat-Panel Plasma HDTV
Mode not supported message
ok there should be be a setting in the menu probably called video source depends on what model it is, make sure you put it on hdmi,this should do it, let me know if it helps
Apr 18, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
I put a regular dvd into my blu ray player but it will not play. the player just says load and when I push the play button nothing happens. I'm using an hdmi cable and my 42 i.nch widesreen sharp tv is set...
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Mar 31, 2010 | Samsung BD-P1600 Blu-ray Disc Player
My tv shows the message mode not supported to a new blue ray player
Make sure the Blu-Ray player is set for 720p or 1080i only as this TV will not recognize 1080p or even the 24fps mode that some Blu-Ray players have.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
I just bought a samsung bd -p1600 and connected to a samsung plasma tv, it just comes up not a supported mode. tried 2 blue ray disks with no luck. switched from hdmi 1 to hdmi 2 input with the same...
Check that the player is set-up in to a mode that is supported by your TV set. You should consult the user manuals of both the TV set and the player to follow through. Another solution which may be easier is to colll the Samsung service support.
Jerry G.
Sep 25, 2009 | Samsung Televison & Video
Samsung PN58B860 58 in. HDTV Plasma TV Logo
549 people viewed this question
Henry  Thomas
Henry Thomas
