Question about Video Game Consoles & Games
Update problem turn on the console it says looking for the update disk. push the a button it says up dating and then said call 800 # or got www.xbox.com. I do not have high speed inter net. if u put a disk in turn it off then turn the game back on it dose not fix the problem. is there a down load disk i can make?
Called 1800 4my xbox they told me that i needed to send the concole to them. They were going to have to fix the problem because it was a core (think ?) system. It is not an elite or pro. Other wise there is a download at there site i could have burned to a dis. Pop that cd in and it would have fixed the problem right away. three two four weeks is the turn around on getting it back. thank for asking and replying
tracy matthews
Posted on Mar 26, 2008
3151-3cd6-b800-0402-c000-0001
Your console had a problem during the update process. Carefully follow these steps:
Remove any disc from the console.
Leave the disc tray open.
With the disc tray open, remove the power cord from the back of the console.
Plug the power cord back into the console. Do not turn the console on yet.
Gently push the disc tray about half-way back into the console.
Push the power button on the console.
Important: Do not use the controller button or the disc tray eject button to turn on the console for this step.
The update should now continue. If the above steps do not work, the console might need to be repaired. You will then have to contact your local phone support.
Jul 21, 2017 | Microsoft Xbox 360 Console
When trying to update I get Error code 32017
hi friend,
Error Code 32017
    There appears to have been a problem performing an update. Power the system off and try the update again
    1. Hold the power button on the front of the console until the light turns red.
    2. Press the power button again to turn the system back on. On the Health & Safety screen, press the A Button to continue to the Wii Menu.
    3. Select the Wii button from the Wii Menu, then select "settings." Select the right arrow to go to the third page, then select "System Update."
    4. Follow the directions on screen to perform any updates available
    5. If it's still not working, please call 1-800-255-3700 so that we may assist you further.
hope this solves ur problem
Sep 17, 2011 | Nintendo Wii Console
My xbox keeps freezing when I play my games then sometimes I get an E 71 error??? what do i need to do?
E71: Dashboard Error - Error within Xam.xex
Try resetting the console - Clear All Installed Game Updates and Console Cache
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
Clear Any Failed system updates that cause the console to error.
  1. With the console off, press and hold the sync up button (the small white one)
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally.
If that doesn't fix it, you'll need to set up a repair with MS.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Jun 27, 2011 | Video Game Consoles & Games
Why does my xbox say system update failed status code 3151-335A-B380-0402-C000-016B?
The update should now continue. If the above steps do not work, the console might need to be repaired. This worked for me, I hope this helps you.
May 28, 2011 | Microsoft Video Game Consoles & Games
I have a slimline ps3 and my hard drive was corrupted so i downloaded a new system update it installed the update it let me adjust the time and date settings and just before it goes to the screen that...
  1. KINDLY REMOVE THE HARD DISK FROM THE CONSOLE
  2. LOOK FOR AN EXTERNAL HARD DRIVE PACK
  3. PUT THE PS3 HARD DISK INTO THE EXTERNAL HARD DISK PACK
  4. CONNECT IT TO YOU COMPUTER
  5. AND FORMAT IT.
  6. REMOVE IT FROM THE EXTERNAL PACK
  7. PUT IT BACK INTO THE PS3 CONSOLE AND TURN IT ON.
  8. IT WILL ASK FOR UPDATE
  9. THEN YOU UPDATE IT.
  10. IF AFTER DOING ALL THIS AND IT DOSEN'T WORK
  11. CHANGE THE HARD DISK INSIDE THE PS3.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Need to selct english on the ps2 box itself,its in asain can u help
Remove any disk and close the disk tray. Turn off your system and let it sit for a few seconds before turning it back on. Select the "Language" option from the main menu to open the language menu.
Move the cursor up using the directional pad on your controller until you get to "Language Select." Push the X button repeatedly until it lists "ENGLISH." This changes the audio settings from English to Spanish.
Scroll down to the "Subtitles" option in the language menu and change this setting to Spanish as well. The subtitles will appear in ENGLISH at the bottom of the screen every time a character in the game speaks. If you wish, you can skip this step and rely only on the audio settings.
Press the Circle button on your controller to move back to the main menu, which will save the settings. Select the correct time and date setting for your time zone, if the system asks you to do so. Push the Circle button again to access the main menu.
Place a PS2 game into your console and let the game load. You should now have ENGLISH, settings on your PS2, including subtitles.
May 05, 2010 | Sony PlayStation 2 (PS2) Console
OK.. I could not get a disk to eject from my wii console. I tried unplugging it and slapping it on the side.. I also found this site trying to figure out what i can do.. I took some of yalls advice on...
Oh my God ;-) Isn't it funny sometimes when you don't notice simple things, happens all the time.
I one time spent 30mins trying to turn on a PC, to only notice I was pressing the "reset" button and not the power button!
Glad I'm not alone.
Jan 03, 2010 | Nintendo Wii Console
Xbox 360 faild update im really madd and only
If you were doing the update through Xbox live here is how you fix it. With the console powered off hold the sync button pushed in. Keeping it pushed in, turn the console on. As long as you are holding the sync button the entire time it should load up to your dashboard and clear out the failed update.
Once you've done that, try the update again.
Jan 01, 2010 | Microsoft Xbox 360 Console
Xbox wont update for new game
try clearing the updates and try it again
turn off, press and hold sync button, while holding that button push the power, keep sync button held in tell completely booted up then u should get a message to update and then try that
Mar 23, 2008 | Microsoft Xbox 360 Console
Disk tray won't open
Call Customer Support: 1-800-4MY-XBOX
Dec 06, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
