I have a Whirlpool Washer LSQ9200LQ1. There is power to the unit and when I put the selector knob in position pull it out to start and there is no action. I thought it was the timer and replaced it. still no action.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 200 Answers
Lid switch need replace
Posted on Apr 25, 2010
All the lights come on but the CAE2793BQ will not runa cycle
We had the same problem. we bought a new control board for a local part shop for $335 (could buy online for $150) The part came with instructions how to reset the LEDs which indicate a failure has happened. This sheet IS NOT included with your manual when you buy the washer. The sheet reads that you need to recalibrate the washer when installing, or after moving unit to a different outlet. How bad is whirlpool not to include this in manual?
to reset: put knob in 12 o'clock position, wait 3-4 sec then; turn knob with the following combination, pausing shortly between clicks (within 6 sec).
turn left 1 click, right 1 click, right 1 click, left 1 click, right 1 click.
success activation of diagnostic mode will be that all LEDs (except lid lock) flashing on/off half sec intervals. Start calibration;
Toggle the cycle knob until the RINSE led is lit;
do not interrupt power, lid must be down, basket empty. press START to begin calibration (3-5 mins).
Lid will unlock and go into stand by mode. If this didnt work then the original fault still exist. It should flash a fault code, but i dont have that sheet. Whirlpool said it should of came with your washer.
hope this helps
Feb 26, 2014 | Whirlpool Heavy-Duty Series Energy Plus...
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
Post the results back to me.
Nov 30, 2012 | Washing Machines
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Washer will not start
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
The timer know on my whirlpool washer does not move. I have to go and turn the knob for the machine to get out of the wash cycle, the spin cycle and the rinse cycle.
If the knob does not move to the end of the wash, spin and rinse cycles (i.e. remains in one position) then the little drive motor that operates the timer/function rotary selector, has either lost power or is faulty.
If you have a multimeter (and know how to use it) then it's easy to determine if power is reaching the motor. If power is present, but no movement from the little motor, then you're probably looking at replacing the selector mechnism. If no power on the mechanism, then you will have to do some visual wire tracing (with power removed from the machine) to determine where the discontinuity is.
Bear in mind that once the washing machine is opened for measurement, you will be exposed to live mains power.
You are liable for your own safety. Take great care.
May 25, 2011 | Whirlpool Hardware & Accessories
The Hold to start button is not starting the washer anymore. It used to work but it no longer makes the click that used to start the washer. It seems to be stuck
The user interface board is not serviceable and it requires to be replaced when it is not working properly or when a button is stuck. The procedure is quiet easy and you can do it yourself.
Disconnect power to the washer prior to servicing to avoid electric shock.
Remove the three screws attaching the rear of the top panel to the back of the washer then slide the panel rearward, and then lift it off the washer.
Disconnect the 7-terminal user interface ribbon connector from the left side of the central control unit.
Pull the dispenser drawer out until it stops; press down the release tab then pull the drawer completely out of the washer.
Remove the screw in the recessed hole at the left of the drawer opening. Press and release the tab securing the right side of the console to the cabinet.
Open the washer door then insert the blade of a flat-bladed screwdriver into the slot at the bottom center of the console then push the console up to release the tab attaching its bottom to the cabinet.
Gently pry up and release the top of the console then pull it off the washer.
Pull the cycle selector knob off the control panel then release the tabs securing the user interface/LED assembly to the control panel. Lift the user interface/LED assembly from the control panel once all of the tabs are released.
Inspect the Hold to Start button and the alleged stuck membrane in the user interface board. Replace the button if it is broken. Try your luck by trying to unstuck the stuck membrane. If no luck at all, replace the user interface assembly.
Install the new user interface/LED assembly into the control panel by inserting it into the tabs from one side to the other until it is completely secured, and then reinsert the cycle selector knob.
Align the console tabs with the slots in the cabinet then insert the tabs into position. Secure the left side of the console with the screw previously removed, and then slide the dispenser drawer back in place.
Reconnect the user interface ribbon connector to the central control unit then slide the top panel back into position and secure it with the three securing screws.
Note: The user interface assembly part number may differ from version to version of the same model. The version is indicated by the last digit of the model number so make sure to indicate the complete model number of your washer located on the left side of the door opening.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
