Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Gardenway tiller, 8hp techumseh, need to know where the gov. spring connects at throttle cable assy. round spring but end is not in one of the several holes at this location and this will not let the engine rev. when throttled up. have a diagram of this linkage? thanks, steve
    Genius:
  • 1,043 Answers
The following is a website link that you can use to download the Service Manual that you need for your particular model:
http://www.scribd.com/search?cat=redesign&q=tecumseh+hm80&x=37&y=23
The manual you want is titled Tecumseh Service Manual. You may have to join the website, but it is a free site and they will not sell your info. The manual is complete with all of the drawings that you need to finish your re-assembly. If for some reason you have any issues with downloading the manual let me know.
Posted on Apr 24, 2010
Tiller runs at full throddle and tines continue to turn. Unable to lower throddle. What do I do?
Sounds like the throttle cable is sticking or the carburetor butterfly is sticking.
Squirt some WD-40 into the cable that attaches to the throttle handle and onto the mechanism the cable hooks to at the carburetor. Carefully actuate the throttle and see if the mechanism is moving smoothly. It may need several squirts and some actuation before it become free.
Jun 08, 2014 | Mantis 2-Cycle Tiller
How to hook up governor spring and throttle linkage on a briggs and stratton 8hp
From the governor 'vane', on end with a small hole in it is for one end of the spring........the other end of the spring goes to the throttle arm on the carb. YOU MUST HAVE THE CORRECT SPRING WITH THE PROPER LENGTH AND TENSION!!!
Sep 21, 2013 | Garden
1987 jr50 throttle cable to carbuator
On top of the carburator is a round cap where the cable passes through, un-screw it, remove the spring underneath, along with the piston/needle assembly. Thread the cable through the cap and then the spring, compress the spring by hand and pull the cable slack through. The top of the piston has 2 holes side by side, one larger than the other,with a narrow groove connecting the two together, thread the cable end into the larger hole and while holding it with one hand, use the other to slide the cable through the narrow groove connecting the 2 holes so the cable end is now under the smaller hole.
Mar 23, 2012 | Motorcycles
Garden Way "Speedy Hoe" with
The throttle cable does not connect to the carburator. The round end of the cable pushes on the throttle plate arm. The cable is spring loaded and returns when you let off the throttle. The throttle plate arm on the carb is connected to the governor- the plastic vane that fits in the slot in the engine top cowl and sticks up into the cowl- by a spring. The air that is moved by the fan on top of the engine pushes on the governor and brings the engine speed down when you let off the throttle on the handle.
Apr 28, 2011 | Garden
Belt will not tighten when tines are engaged
There should be a spring on the other end of the engagement cable connected to the take up (idler) pulley. It sounds like it have broken or came off. You will need to removed the side cover and inspect. After you have the cover off, pull the engaging bar and watch the take up pulley for correct operation.
Jun 02, 2010 | Craftsman 8.50 Torque Rating Dual...
Have hooked spring at throttle to govenor but now seems to stiff. did i get it hooked to the wrong place? it's on a maxim tiller 5 hp briggs 130202 3131-01
on a b/s 5hp the small governor spring goes on a thing that has two ears in it.take the tank back off and as you bring it back in place you will take the gov. spring and turn the top part of it sideways to slip over the ears of the spring holder.when you have it on the spring should be below the holder with the top of the spring in a groove that is between the ears.make sure the white kill wire is out of the way of the throttle cam.this should have the governor spring on correctly.
Mar 16, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Rototiller pull start won't pull
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
Jul 28, 2009 | Husqvarna PRRT850X 960920015 CA 17" Rear...
Bought a new part to hold the starter cord for my tiller
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope through from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 01, 2009 | Troy-Bilt Garden
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
301 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
