Printer shutdown after sheet of paper lodged and was removedfrom
After paper was lodged it was removed. Red exclamation mark came on and printer will not reset
Unplug for a few mins
Posted on Apr 24, 2010
My printer cannot initialize
1. Might be small paper peaces stucked inside.
2. Paper path sensor(any one) flag broken/displaced/spring displaced..chk..
May 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
Unable to close error message "Paper Jam"
unplug the printer, inspect it for paper jams, take the printer apart as far as possible and clear any paper jams in it.
for more specific instructions I will need to know the brand and model of your printer.
Thank,
Ekse
Jul 07, 2008 | Office Equipment & Supplies
SCX 4521F multi/f keeps reporting "Document Jam"
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Ensure that:
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cannot print
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Nov 21, 2008 | HP LaserJet 2200dtn Printer
Paper feed on Canon i 350n ink jet printer
Ensure that:
The paper is a recommended paper for inkjet printers.
May 13, 2008 | Canon i350 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Jammed paper
Ensure that:
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Paper jam
Ensure that:
Jan 04, 2008 | Lexmark X1240 All-In-One InkJet Printer
k24674
jasbo
jasbo
