Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Raypack Pool Heater
When heater is turned on, it tries to spark but the blower doesn't turn on. On time I wiggled all the wires and it did turn on, but have not been able to repeat. Heater is 5 years old. Two years ago, a similar problem resulted in the "starter?" being replaced. Which part might that be?
  • 990 Answers
A starter would probally be a start capacitor for the blower motor. If you can wiggle wires and get it to start it is more probally a bad wire or a connection. If you clean all the connections check the wires expecally at the point where they go through zip ties and the like. Also check the air sensor connected to the blower housing by a hose and the wires connected to it.
Posted on Apr 24, 2010
Raypack pool heater trouble codes
check flame sensor if wired 120 volt see wiring on inside of panel
Jun 22, 2014 | Raypak Rp2100 Digital 336k Btu Propane...
Raypack 2100......cfh then spark after a few moments.....what appears to be :Lo.....what could this be
check gas pressure sounds like too small meter especially if furnace or dryer is running call gas company give them added value of all gas operated appliances
May 24, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
A contractor just install a new Hayward H serie pool heater. Every time he turns it on, teh 240 amp breaker trips. He has suggested the heater is defective from teh factory. Any suggestions?
He suggests? If he disconnects the heater I assume you can turn the breaker on and it doesn't trip, correct? Has he checked the wiring for grounds? Double checked he's wiring it correctly? The heater's wiring connection is not color coded the way you normally find a 115 or 230 V circuit. He should have the black and orange wires connected to the 230V lines, the white wire capped off and the ground to the chassis. If all that checks out then yes, the heater has an issue. If he is not a warranty service provider please visit the Hayward site to get one out there. You can find them selecting service from a drop-down menu after you enter your zip code here:
http://www.haywardnet.com/locator/
If your initial search doesn't bring up a provider increase the radius until you get one.
Jun 06, 2011 | Hayward H-series Electronic Gas Pool...
Blows thermal fuse on raypack heater?
If you are talking about the "Roll out sensor" located on the lower left hand side, you have a problem with ventilation..Soot,debris, or possibly a rodent nest on the heat exchanger (Located just under the top cover of the heater). If it is electrical, you may have a bare wire touching the heaters housing (somewhere inside) causing a short. Rodents love to chew the insulation off low voltage wiring.
Oct 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Jun 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Raypack pool/spa heater works intermittently
You can try pulling your pilot assembly out and clean it. Sometimes it will get sooted up and cause the sensor to short so the heater get's a falce reading and shuts the heater down. Then sometimes the heater will start and sometimes it won't. If this dosen't help check the ignition wire for any cracks or anyplace it may be shorting. Good luck.
Feb 17, 2010 | Raypak Versa 130,000 Btu Above Ground...
Raypack RP 2100 The heater doesn't turn on, is there a reset
the electronic heater has an on off switch on the side on older models on the front on newer.the power goes to a transformer this in turn is converted to low power .
Jul 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
94 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
