Question about MTX Thunder 6152 Car Audio Amplifier
I just got a mtx thunder 6152 amp got it all hooked up its working but red light is on, should it be red or green?
Is supposed to be green, maybe it is protected
if so you have to do is remove the jumper will be, and
for about 10 seconds and then put it back
or reset to remove the protection.
does not work now if what happened is that the channel hit
that as wrong?. because they put the speaker cables if invented
positive that should be negative. I hope you
help that you are well
Posted on Sep 02, 2010
  • 22 Answers
Http://www.mtx.com/caraudio/archive/NDM185.pdf .... go to this link for more help, it is the owners manual
Posted on Apr 25, 2010
  • Mark Skinner Jan 30, 2011
    I repair car amps for a living. I have 17 years of experience and an electronics engineer degree. It's in protect mode. Either you have a power supply problem or the out puts are shoreted. My prices are the cheapest in the USA and I also give a 90 day warranty. I don't charge a bench fee and my prices rarely go over $60 to $80 depending on the problem.
    If you need help let me know and I will help you out anyway possible.
What other MTX Thunder amplifier can i hook up with a MTX Thunder 6152 amplifier??
Not sure what you are trying to do, but you don't hook up one amplifier to another. You can pick any brand or model amp to drive other speakers than the ones that you are driving with the 6152. Just consider the power needed to push the speakers at the impedance they are rated(and hooked up)at. Look at the owners manual to determine if you need another amp. Hope that helps a little.
Apr 16, 2014 | Car Audio & Video
Whattx thunder amp would or can go with Mtx thunder 6152 amp?
I can see were you would need the amp to be compatible with the deck but with another amp? the amp is amplifying a specific channel, front or rear speakers and for base only when the deck has a subwoofer pre out built into it. as for compatibility between the amps it would all depend on the sound you want and location and size of speakes will also play a part in that.
Mar 01, 2014 | Car Audio & Video
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
Is the MTX thunder 6152 r capable of 1ohm
its capable of a minimum of 2 ohms; the sticker on the bottom should say
Jan 22, 2011 | MTX Thunder 6152 Car Audio Amplifier
When i try to hook up amp no lights turn on.im pretty sure it works.how can u tell if its burnt up
first thing to do is smell it, second thing to do is to take the bottom covor off to visually check for damage, third is to bench test it with a car batter, a regualar 4 ohm speaker that you know works, and a cd player with rcas going into the amplifer, this is the best way, then if it works on the bench, it must be something with your wiring, bad ground, loose battery clamp, etc.
Aug 09, 2010 | MTX Thunder 6152 Car Audio Amplifier
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
MTX Thunder 6152 Car Audio Amplifier Logo
252 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
