Question about SanDisk Sansa e250 MP3 Player
Sansa e250 What if there is no format option .. ?
  • 8,596 Answers
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Posted on Apr 08, 2008
SOURCE:
My sansa e250 not play video files when connect to the system throug sansa video converter it tell your snasa not support video format
my ipod is sansa e250. the problem is im not able to load videos in my ipod.i can see in through system the videos are present in ipod but when i plug out and see in ipod the videos are not there.please give me a exact solution
Nov 15, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 lost all my songs
Hi
those files are hidden files.....in your pc just Go to my computer ->tools ->folder option ->view->show hidden folders ....displays hidden files .....still cant find any files ...check memory status of the external card.....format it ......download songs to it....
Feb 06, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 still sandisk
If the Sandisk sansa e250 appears under your computer you can format it by simply right clicking it and selecting format.
Quick format usually works best but make sure no applications are using the device when you format. If applications are using the device when you attempt to format you will get an error message that will prevent you from continuing.
You can disable any applications using the player by going to the task manager.
Jan 04, 2009 | SanDisk Sansa e250 MP3 Player
Formatting a Sansa e250
Plug it in, open "My Computer" right click your device and click "Format" a window will pop up with the settings on how you want to format it, make sure it's set to FAT, then click "Format."
Hope this helps!
Oct 13, 2008 | SanDisk Sansa e250 MP3 Player
I cant add videos to my sansa e250
download the latest version of quicktime and try again
Aug 10, 2008 | SanDisk Sansa e250 MP3 Player
Formatedmy sansa e250 ntfs
To format it..on your device..go under..menu, setting and there should be a format option option there.. or you can change the device mode to MSC instead of MTP and right click on the drive which is listed under my computer and click on format..
let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Jul 30, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
reload the firmware from Sandisk's website, if they strill carry it - i heard rumors they discontinued it
Jul 15, 2008 | SanDisk Sansa e250 MP3 Player
Formatting
If for some reason the Format option is gone, then perhaps some of the firmware or settings have been drastically changed or worst, corrupted.
A couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased;
If the above will not work, you can also try:
1. download and run in your PC Sansa Connect Recovery Tool
2. read the How to use the Sansa Connect Recovery Tool and follow the instructions carefully;
3. doing #1 will erase the corrupted files, unfortunately so with everything else. It will then restore the device software to an uncorrupted state.
Hope this be of help/ Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 07, 2008 | SanDisk Sansa e250 MP3 Player
Formatting the sansa e250
Yes, formatting will retain the interface and everything else necessary to run the device. It only removes what you have put on the unit. Also, format anytime you begin to have strange problems with the device that can't be explained...like songs that don't appear after you've transferred them.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa® e250 MP3 Player 2GB
Mikey25
Once you connect your Sansa® e250, a pop-up should appear on your computer that asks what you want to do with the device. Choose View with Microsoft explorer, it should be the second to last option. From there you should see some folders and some other stuff. choose the PHOTO folder and delete the pictures inside. You should be able to do the opposite to add them. You can simply drag-and-drop the photos into this folder from another as long as they are the same format.
Aug 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
