Question about Microsoft Windows Vista Ultimate Edition
Cannot install Windows XP,Vista on Compaq Laptop(FreeDos) V3607TU.
I am Jigar Mehta, I Cannot install Windows XP,Vista on V3607TU Compaq Laptop(FreeDos).
Its Not Detecting the Hard Drive during OS Installation , its a SATA Hard Drive and also i have tried Installing the Windows Vista as i was advised, But NOGO.
Also i tried downloading the SATA Drivers from the HP Site
SP37005,SP36056,SP33020,SP37697,SP36881,SP32478.
Also i Tried the SleepStreaming using nLite Software, also i tried Integrating the Drivers with the Windows OS CD,NOGO.
Would you please help me withis issue as i have 120 GB SATA HDD , and i want to install SAP Software on the V3607TU Compaq Laptop(FreeDos).
but i cant do it till i have Operating System Installed :(
i thank you in advance to help me Resolve this issue ASAP,
My Email ID :- jigarmehta81@gmail.com
  • 7 more comments
  • Jigar Mehta Mar 23, 2008
    hi Rahu...
    I m having 2gb RAM. however the problem is not with the RAM. the system is unable to find the SATA drivers even when trying to install the Windows Vista...I guess Vista has the SATA drivers integrated in the OS??? please reply
  • Jigar Mehta Mar 24, 2008
    Dear Iqbal, thanks for the probable solution...i ll definitely try that..however could you let me know which driver to download from which website??? also I m not having a USB floppy drive handy with me....i tried the following websites but that didnt work....i think i m doing the slipstreaming proparly but the driver or controller required by my laptop are not available......IF YOU COULD PLEASE HELP ME TRACK THE CONTROLLERS I REQUIRE...I WOULD BE REALLY BEHOLDEN
    heres the link for my compaq V3607tu specifications also there are some other links which might be useful for others but non working for me
    1model number : V3607TU
    http://tinyurl.com/2so23k
    hdd: sata hdd with 120 gb space
    in bios sata native option unavailable
    SATA drivers as from the HP website : sp32478.exe
    website url: http://tinyurl.com/2rv4mx
    other support links
    http://tinyurl.com/ysryd2
    http://tinyurl.com/2nzgz4
    http://tinyurl.com/36wkg2
    http://tinyurl.com/39a7yh mtorrent win vista mini xp
    your help in any regards is highly appreciated
  • Anonymous Mar 26, 2008
    sir,
    i have the HP laptop 6314tx and i can`t install the xp in it . i have window vista ultimate installed in it . please reply me though my id naj_sadiq_2006@yahoo.com
  • shaillandra Jul 02, 2008
    hi...
    i bought compag laptop with free dos i tried installing xp but it is not getting installed it is comming like no hard drive found so please try to help me...
  • idafuro12 Jul 15, 2008
    i have a hp Compaq 6720s 111gig, 1gig ram, and after formatting can not install windows xp on my laptop any more, it is asking to run manufacturer setup program or hard drive not found, please help me resolve this problem, i have vista and Ubuntu running, but prefer win xp 2 and 3.
  • Anonymous Sep 01, 2008
    i used to have a windows 2000 on a Compaq proliant DL380 server, but i needed to install Windows XP 2005 on it, so each time i try to setup, it brings back a report of not being able to find any hard drive installed, So please does any one help me out. the hard drive is a 9.6g SATA
  • dhiva_315 Jan 21, 2009
    hi guys,
    would u pl help me regarding this issue ..
    I have bought compaq cq40 144tu freedos edition
    but am unable to load xp ,i don't have usb floppy drive to boot from it..
    It is sata hardisk i think problem lies with harddisk support ..
    Kindly help me to sort out the issue..
  • dye_penny Feb 12, 2009
    how can i downgrade my laptop hp pavillion dv600 to windows xp.. another thing i cant reformat my laptop coz i dont have the installer for my components and another thing can i download the hp recovery.. if yes where..
    thank you in advance to those who have a golden heart to help me.. as u can see m so inexperience and a mess
    tnx dye
  • tms_raja Mar 28, 2009
    cannot installed windowsxp in elite 8430in hplatops please do the needful
I have two solutions for this problem. the first one is to change the bios settings. the solution is here:  http://techrena.blogspot.com/2008/10/how-to-install-your-own-wndows-xp-in-hp.html
but for some laptops this setting is not available. so you can try another solution i.e. integrate the SATA drivers in your windows XP cd. this solution is here: http://techrena.blogspot.com/2009/01/integrate-your-own-drivers-or.html
Posted on Jan 30, 2009
  • 111 Answers
Hi!
One easy way to address this problem is using a usb floppy disk drive with sata drivers on it. If you intend to install dual OS, start with XP, the process will be...insert your floppy to your usb FDD make sure that your USB FDD is connected to one of your USB ports and power up you Laptop and insert your XP installer. During boot up if your system is set up to boot from CD drive it will ask you to hit any key to boot from cd and upon seeing the blue screen you will notice a"press F6...." note on the lower part of your screen. Make sure to Press F6 several times just to make sure that you send the command to get the drivers from other source. At a certain point there will be a screen that will ask you if you want to load the drivers "Press S" press S and choose from the lists of inf files shown. (Note I suggest you add all of them). If the driver that you loaded was the correct one then your good to go.
hope this helps.
Posted on Mar 23, 2008
  • 655 Answers
Jigar, I have HP Pavilion dv6000, it comes with Vista Home Premium Loaded. But as I am a programmer I also need the XP on my lap.
So I tried the same as you have done. And I fixed the problem.
You are doing one mistake as i think, don't down load SATA from HP web, goto Intel and download SATA driver for your Motherboard, as per its Family, mine was Intel(R) ICH8M, the driver will be a selfextract file, extract all these in a folder and run nLite, and add the drivers from that folder, it will list you all the drivers as per INFs . Add all and burn the CD.
Then use this CD I think it will work surely.
Thanks
Iqbal
  • Iqbal Husain
    Iqbal Husain Mar 23, 2008
    Jigar I know RAM is not your problem, the problem is for SATA driver. Follow the my above instruction. It will fix your problem.
    Thanks
    Iqbal
  • Iqbal Husain
    Iqbal Husain Mar 24, 2008
    My openion is regarding USB floppy drive is not the solution, becoz windows XP setup could not recognize that. You can use USB Floppy only after complete boot-up of XP. So if you will put the SATA driver (i.e. RAID for F6) it will not work. Becoz as well as you will press F6 the setup will raise an error that no floppy drive is found as to access the USB floppy drive the USB driver must be loaded before of use.
    Jigar here is screen my screen shot from my device manager:
    Please make a same screen shot indicating SATA AHCI Controller. and post it here. Then I can send you the link.
    Thanks
    Iqbal
Dear all,
MY problem was solved by using nlite ..
Guys do use nlite and solve the issue
dont waste money on buying nlite .
but one issue is very difficult to install drivers..
Posted on Jan 31, 2009
Dear friends,,,, i think i have the required driver which i need to install before installing the OS. now the only problem is how to integrate....if neone can give me step by step instruction on how to integrate the drivers using NLITE i would be more than happy
the driver name is intel r 82801
Posted on Apr 28, 2008
the driver name
the driver name is
the driver
the
Disable the SATA option under advance options in BIOS. That should work and it will also allow you to install/reinstall Win XP.
abdul.lateef.03@gmail.com
Disable the SATA option in advanced option under BIOS.
You should be able to install/reinstall win XP.
abdul
    Problem Solver:
  • 13 Answers
Have u check ur bios will it find ur sata hard disk. as I am sure for windows vista u dont need to install sata driver and now adays bios can easily find sata hard disk first check ur bios and find ur sata hard disk there. for more windows vista tips for troubleshooting visit -- http://vista-basic.blogspot.com/. here is one more way for how to improve sata disk performance vista
Posted on Apr 19, 2008
Hi there...can anyone please let me know the steps for the drivers integration using nlite....also i wanna ask IQBAL where did you download the motherboard drivers...can you provide me the link???
Posted on Mar 26, 2008
Hi Iqbal...could you just let me know how to integrate the SATA drivers with the Os using the nlite software.....i have the drivers as exe file ..so i need to convert(extract) them in some other format. please advise me in this regard.....you can reply to me on jigarmehta81@gmail.com
Posted on Mar 25, 2008
Hey Iqbal.. thanks for your prompt reply.however I m unable to install the OS on my computer...the HDD is completed FORMATTED. is there any means to detect the SATA drivers without the Device manager??? also the bios doesnt give any information about the devices...Please HELP. Please give me a breakthrough in my issue!!!!
Posted on Mar 24, 2008
Vista is minimum requrment of upto 1GB RAM then u install vista
Changing OS from windows vista to xp
You can install xp on a vista laptop, you will need an xp install cd and you will need to backup your data (it will be erased in the downgrade process). As for the drivers, go to your laptops manufactures site. They will have a support section for your laptop model where you can see if there are drivers for xp. If you have the hardware that will support windows 7, I would go with that. Xp is slow and no longer supported by Microsoft as of April 2014, which poses a security risk. Windows 7 will be supported for a while and is faster and more stable than xp or vista.
Nov 30, 2013 | Compaq Presario C700T Notebook
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both...
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Sep 24, 2009 | Compaq Computers & Internet
XP support drivers for inspiron 1525
hi there,
try to download the drivers here:
http://jigar-mehta.blogspot.com/2008/02/where-are-xp-drivers-for-dell-inspiron.html
good luck
Aug 08, 2009 | Dell Inspiron 8000 Fan Laptop Cooler
Can i install windows xp or windows 2000 in Compaq CQ 60-104 TU?
You can install Windows Xp.However, windows 2000 is not successful on this.
Thanks.
Jul 24, 2009 | Computers & Internet
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
How to disable sata in bios of compaq CQ40 laptops
have an compaq presario cq40-301tu laptop want to load xp already vista is loaded in that while installing xp i get an blue dump error & no setting in bios found to make sata compatible please give me the solution how i can install win xp2-
Nov 27, 2008 | Compaq Presario Notebook
CQ40-108TU XP DRIVERS
i have found this from another forum hope it will work:
For Installing Vista, some users reported that after resetting the BIOS to default (F9), the VISTA installation running smoothly.
In your bios the information of "non vista os installed" is "the Factory installed OS" for this laptop. Probably, you bought this laptop with freedos OS.
I recommend you to install VISTA for this model, however, some users with their own reasons feel the need of XP as their OS.
Up till now, they end up having a hardware conflict between Audio and modem. Some of them can tolerate it, some still finding for the solution.
Unfortunately, they could NOT ask a help from HP/Compaq since HP/Compaq ONLY support VISTA for Operating System.
A policy that encouraged by Microsoft to FORCE users to migrate to VISTA
Nov 24, 2008 | Compaq Presario Notebook
Installing windows xp to compaq presario 700 pc notebook
HP Compaq Presario 700 series was originally designed for XP and Vista, therefore you can install XP on it.
After installing Windows XP, you will need to install all drivers.
You can download drivers and software for your laptop from HP here.
Oct 07, 2008 | Compaq Presario 700 470024-192 Notebook
Audio not working
sherylannie,
does your Compaq Presario SR1435IL have the original FreeDOS, or do you have another OS installed? If you still have the original FreeDOS, I would reccommend upgrading to at least Windows XP, depending how much memory you have in it. If you have the factory 256MB of memory, Windows XP should work, but if it's too sluggish, I'd personally reccomend at least 512 MB, but if you want Windows Vista, my personal opinion would be at least 1GB. Or, if you already have XP, click "Start", then click "Control Panel", then "Printers and Other Hardware", then, on the left, you should see "See Also" and click on the first line that should read, "Add Hardware". Click that and you should be able to follow it from there, just follow the prompts. It isn't all that difficult, if you just know where and what to click. Other than that, if nothing seems to help, maybe you can go to HP's web-site at: http://www.hp.com/support/chat, or you might have other options available at: http://www.hp.com/go/assistance. (The only reason I know what little I do, is because I own A Compaq Presario myself, lol. I hope I've been able to help, and if not, try those websites mentioned above.
Jul 18, 2008 | Compaq Presario 7594 PC Desktop
Thanks for the information (i ll try it with a little help from your side)
Jigar here is the screen shot from my device manager:
Please take a same screen shot from your device manager and post it here. Then I can give you the actuall link for your SATA driver.
Thanks
Iqbal
Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
7,242 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
