Printer the printer doesnt grap the paper enought to print on it EPSON Stylus DX5000 Series
    President:
  • 2,072 Answers
If it is not pushing the paper out of the tray, you should first try taking a soapy cleaner like fantastic or formula 109 and clean the feed rollers and see if that helps.
The paper tray also lifts up and down to feed the paper so the gear that drives the tray up and down may be broken.
Slen the rolls first. If that doesn;t last long. Say in a day or two it starts misfeeding again, the rollers will need to be replaced.
Posted on Mar 24, 2008
Hi I have a Stylus Epson DX5000
Online Best Epson printer support by toll free phone number 1-800-204-4427 to fix troubleshooting issues. We provide Epson printer technical customer service ...
Apr 13, 2017 | Epson Computers & Internet
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Epson dx5000 print heads
are you sure that its the p head problem?if its clogged ,try dipping the head part in hot water a few mnts and test print if not clear try again a few times print should come neat
Mar 07, 2009 | Epson Stylus DX5050 All-In-One InkJet...
E-04 problem. doesn't appear to be any paper jammed. Fix?
PUSH FRESH SHEET A4 FOR ROLLERS TO GRASP.IT CLEARED MY BLOCKAGE. TRY SLIGHTLY CRINCLING THE PAPER TO ROUGHEN IT UP IT MAY PUSH BLOCKED PAPER OUT
Feb 27, 2009 | Epson Stylus DX6050 All-In-One InkJet...
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other...
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Feb 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Need instructions for epson stylus dx5050
Here is guide for CX5000, that is same model as DX5000
User's Guide
Below you also find assembly instructions:
EPSON STYLUS CX5000 / DX5000 / DX5050
Jan 30, 2009 | Epson Stylus DX5050 All-In-One InkJet...
225 people viewed this question
jasbo
jasbo
