Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Using Win 2000 on a laptop, Notebook adapter WPC54GV3 and a wireless-G Linksys router and up to date driver. Will not connect, inactive adapter.Do you have a solution ?
  • Linksys Master
  • 2,263 Answers
It says the adapter is inactive. That means the adapter is not detected by the Linksys utility. Try to unplug the adapter and plug it back in. and restart the computer. now check if iot says active. If not then open the device manager and check if you can see the adapter there. If not then the adapter is not detected by the computer.
Try to uninstall the adapter and reinstall it. Make sure that you have the CD of the adapter before you will uninstall it.
Posted on Apr 24, 2010
Card is inactive
You might want to make sure that your wireless adapter is enabled. Depending on what operating system you will need to go into your network connections area and enable it.If you have a laptop make sure that the switch has been turned on. It is usually located on the front side of the laptop.
Jul 24, 2010 | Linksys WPC54GS Wireless Adapter
Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Dec 13, 2009 | Belkin Computers & Internet
Using a linksys g adapter card in my laptop cannot get internet
U have to configure the router.Then & then your internet will work.You can see the instruction set given with the linksys router or instruction set cd.Follow the steps,which will ask you ip,user name,password etc. information.Fill the right information save & reboot it must work.
Jan 03, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
No Installation CD for Wireless-G Notebook Adapter
Hello! It is possible to install it without the CD< but not easily >You will need to, On a separate computer, Go to Linksys.com and download the drivers, then just burn them to a CD< or Put them on a flash drive, and install it on the laptop. Unless the laptop has a Ethernet port, then just connected the computer to the linksys router VIA Ethernet to download the drivers.
Nov 24, 2008 | Linksys Wireless-G WRT54G Router
Lost cd rom to download Linksys wireless G notebook adapter
Hello there.
You can download the drivers (that are usually on the CD) from here. Please select your 'Version' from the list. You can look at the back of the device to find out which one you have, as there are many called WPC54G. Then after choosing the version click GO then click on 'Driver' to start the download.
This will let your wireless device function on your laptop computer.
Hope this helps.
Jul 02, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
"WPC54G is not installed"
Those install programs that Linksys uses are terrible. This happens all the time.
You probably can't use the linksys program to install the software on a Windows 2000 machine you should be able to install just the driver you need. I have never used wireless networking on a Win 2000 computer before. Win XP has sotware already built into the operating systems to deal with wireless networking.
Uninstall all Linksys wireless networking software. Restart you computer with the wirless network card install and let Windows search for the correct drivers on the CD.
Jun 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Wireless card won't connect to a network
If you're using the WLAN, edit the default profile and ensure that it matches your router's wireless settings
Dec 25, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
111 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
