Toshiba DVD setup
Just purchased Toshiba DVD Video Player & Video Cassette Recorder (SD-V295KU). It is working - turns on & off, drawer opens & closes. How do I assure it is set to channel 03? I don't see instructions in manual; couldn't find on their website. I don't know how to set it up!
It is not responding. I have hooked it up to Comcast Motorola DCT700 cable box, & Sylvania SST4192 TV. I simply want to be able to watch a DVD - nothing fancy!
Thank you
SOURCE:
  • 6 Answers
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Posted on Jan 27, 2009
  • 3 Answers
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Unit must get the TV guide from an analog station. If cable company goes digital you loose the data. If the station that hosted TV guide goes digital you loose the data. This unit does not have a digital ATSC tuner only analog NTSC tuner. If you are still getting analog data there are a few capacitors on the power supply under the hard drive that bulge up and cause problems. They should be replaced with higher voltage rating types.
Posted on Feb 08, 2009
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Posted on Feb 24, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
Professeur_D
  • 42 Answers
SOURCE: Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Posted on Aug 31, 2009
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
Toshiba dvr19dtkb2 dvd wont play on computer after transfering form video casette
The proper codec may not be loaded on your computer. Find the format your DVD recorder uses, Google for a codec for that format. Find a player that supports the code, download and install it onto your computer and then try the DVD.
Mar 31, 2014 | Toshiba DVD/Video Cassette Recorder...
How Can I record a TV program using my SD-V295KU. Where Can I chose the chanel number? Can You hepl me please? This is a DVD Video Player & Video Cassette Recorder.
The SD-V295KU has no tuner. You will need to connect it to a set top tuner, a cable or satellite receiver box. One of the digital-to-analog converters would work for OTA programs from a digital station. The basic ones that were available with the government coupon give SD output; this is sufficient since composite video is limited to SD.
Then connect the composite (audio and video) out from that box to the DVD/VCR composite in (the rightmost jacks). Then set the channel on the box and record content on Line 1 (Press Input Select on the DVD/VCR's remote to get to that input after you set the recording speed.)
Most TVs do not have a composite out option so the tuner in the TV can't be used to feed the program to the DVD/VCR.
I wish that I had better news for you.
Jun 04, 2011 | Televison & Video
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
DVD won't eject from Toshiba DVD player. I have already taken cover off and can manually engage the tray. When I try to eject with the remote I just get a little ''lock'' icon on my TV screen.
Press setup subtitle 3 audio 0 to unlock ...worked for me. Thank a user on Videohelp.com for solution:
http://www.videohelp.com/forum/archive/toshiba-sd-v295ku-locked-tray-solved-t362810.html
Nov 15, 2009 | Toshiba SD-V295
Need missing owner's manual; cannot find on Toshiba's site
The manual can be found here:
http://www.managemyhome.com/mmh/owner_manuals/search?query=Toshiba+SD-V295KU
Apr 26, 2009 | Toshiba SD-V295
Toshiba SD-V295KU DVD/VCR Setup
Hi, David.
This unit does not have a TV tuner built in. It can record only from a video/audio source such as a satellite receiver or cable box. That's why you can't find anything in the manual about programming a channel. It doesn't offer that capability.
Not the answer you were looking for, but that's what they give you. The only solution I can offer is to keep your old VCR or pick one up at a thrift shop, and use it as the signal source. Program it to come on at the desired time on the channel you want, and use its video/audio outputs as the source for your recorder. Program the recorder to start at the same time.
Kinda klunky, but it would work.
Jan 30, 2009 | Toshiba 27DF46 27" TV
Toshiba model sd-v383sc
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
Dan
Jun 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Jun 24, 2007 | Toshiba M754 VCR
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Ekse
