Question about Char-Broil 463232103 Grill
Spring startup gas will not ignite completely
    Guru:
  • 1,051 Answers
You'll need to remove the burners and make certain there's no debis blocking the holes. Dirt, rust and spider webs are common obstruction and need to be cleared away. Also make sure gas feed tube is firmly seated to burner.
Posted on Apr 25, 2010
Flashback on startup
clogged heat exchanger, clogged burner orifices, blocked venting, improper gas pressure, etc.
Apr 14, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Tip
Replacing an Oven Igniter on a Gas Range
This advice is for GAS ovens with glow bar type igniters. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance. But, first, here’s a little gas oven theory to help you better understand how to determine if an igniter is bad:
The way the ignition system in most of today’s ovens work is like this:
  1. Set the oven or broiler temperature.
  2. The igniter begins to glow.
  3. Once the igniter reaches a certain current potential, the gas safety valve opens.
  4. Gas is introduced into the manifold and you have ignition.
  5. NOTE: It can take roughly 30 – 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn’t light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it’s an easy assumption to make that the igniter may be bad, if one or the other doesn’t light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
on Dec 04, 2009 | Kitchen Ranges
Tip
on Feb 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas smell during startup of GE hot water heater
yes, provided there is no excessive build up. The gas and air mix must be right before the mixture will ignit. a household stove will do this each time it's turned on. That's why yhe igniter sparkk hits about three times before it lights. proper venting will confine any fumes to the cimbustion chamber to be carried out the exhaust. If the odor is strong then have the appliance checked for safety sake.
May 02, 2009 | General Electric GE SmartWater Household...
F250 powerstroke on startup the starter engaged and wld not stop
sounds like the return spring is worn or dislodged
Jan 05, 2009 | 1995 Ford F250
Oven Burners not lighting completely
It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
Replace both igniters.
Dec 23, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven takes way too long to heat
This advice is for GAS ovens with glow bar type igniters. This is how to determine if the igniter is bad. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance.
An igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad. An igniter should only take 30-90 seconds to ignite.
Mar 24, 2008 | Whirlpool SF315 Dual Fuel (Electric and...
Whirlpool SF365pegq
The way the ignition system in most of today's ovens work is like this:
5. NOTE: It can take roughly 30 - 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
Carborundum (Cylindrical in shape) - needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) - needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn't light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it's an easy assumption to make that the igniter may be bad, if one or the other doesn't light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn't produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won't light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we're going to assume you have a bad igniter and need to replace it. Follows these steps:
2. Open oven door and remove (if possible). Refer to your owner's manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn't shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 - 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2008 | Whirlpool SF369 Gas Kitchen Range
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Char-Broil 463232103 Grill Logo
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
