Question about Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator
Jcd2389ces coils keep freezing up and freezer wont cool. after defrosting by hand works well for 2-3 months then happens again
  • Jenn-Air Master
  • 43,501 Answers
Posted on Apr 25, 2010
We have Frigidaire Upright Freezer. After 6-7 days its stops cooling as its condenser gets ice around it whereas the fan is working good. We clean the ice and it again starts working/cooling.
There are a few possibilities. Freeze-ups are a result of the unit either not having sufficient airflow or the compressor running too long and too often. As you note the fan is good, chances are airflow is not the issue. There are a few quick items that you can check on:
1. Check door seals. Leaks will cause the interior to lose cooling faster and result in compressor overloading.
2. Do not overload the freezer. Too much inside the freezer will cause loss of airflow INSIDE the unit and can cause issues.
3. Avoid putting too much unfrozen material into the freezer at once. It takes a lot of work to remove all the heat from a large amount of material.
4. Avoid multiple opening and closing of the door. Upright freezers are inefficient as they lose all their cold air as soon as you open the door. Chest freezers do better if you must go into the unit often.
Lastly, undercharged refrigerant system can cause the same issue. If you don't have any of the other problems noted, have a serviceman check the refrigerant and fill the system as needed.
Feb 29, 2016 | Frigidaire Freezers
Model number KFN9753ID freezer section not freezing. what do you think the problem might be
Might be the defrost timer failing - that happens. The evaporator coils freeze up then, and very little air can pass the ice-clogged evaporator coils.
It's only been happening since the onset of humid summer weather? Check the defrost catch pan underneath - I'll bet it's dry. Defrost the refrigerator manually (unplug the refrigerator, put everything into coolers wrapped in blankets, etc) for a good long while, then plug it back in again - I'll bet the freezer works like gangbusters again for a while. If so, and if it stops again after a day or two... then I'm VERY confident that the defrost timer board is ready for replacement.
Jul 29, 2014 | Miele Refrigerators
The coils in the freezer department keep icing up completely. I manually defrost and then it works for a time (a couple of months) until the coils freeze again.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 09, 2011 | Refrigerators
I have a 20 year old side by side sub zero. For the last few months i have had problems keeping the temp even in the refrigerator side, either freezes or gets too warm. Now it wont get colder than 45 or...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Sub-Zero Refrigerators
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
I have a Frigidaire PLHS67EEsb7 side by side. Every couple of months, something happens that causes the coils in the freezer to freeze over and the fridge and freezer stop cooling altogether. I have to...
clean out all the vents,syringe the drain holes with clorine bleach,check the door seals for air tightness all round...after a full defrost(do not help it with a hairdryer as this only defrost the ice you can see....try to defrost it when you can leave it for 24/36 hours....with the doors open and switched off....then dry thoroughly.
Jul 20, 2010 | Frigidaire PLHS67EESB Side by Side...
GE ESS25XGMB WW freezer is not cooling everything melts. I've cleaned coil with vacuum unplugged and plugged back in and is working again.....but in time it will get warm in freezer again
How long did you unplug it for? A longer amount of time might have let the defrost coils melt. If your defrost coils keep on freezing up, the defrost timer might be bad.
Sep 22, 2009 | Refrigerators
Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
Mar 30, 2008 | Frigidaire FRS26ZSG
Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator Logo
70 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
