Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a 1020 john deere and there is hydrolic fluid in the oil put a new power steering pump on 2 years ago when it was doing the same thing Is there a ball or a setting pin that goes on the end of the shaft and into the block?
Power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
Posted on Nov 11, 2010
How do I check the hydraulic fluid level on John Deere 1520
dipstick\\\ on the back of pump , or look into return tank see if you can see oil 1/2 way up in tank
Mar 11, 2016 | John Deere Tractor 1020, 1520, 1530,...
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
Where do I put the hydrolic fluid in a John Deere 755 tractor?
yvCTPtnpOroaDOyyi9dZt5aw7XkS2RQ">
Little yellow plug is the hydraulic oil fill plug.
Jul 22, 2014 | Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
All hidraulics funtions are dead, no hydraulic power in machine.
first thing I would do is test the pump itself even if no wear is found you could have a GPM loss.
So you need to do a flow test on it to find otu how much the loss is and check it to the specs of that hydrolic pump first.
May 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a 4120 PowrReverser with a similar problem. Machine was working great. Turned it off to talk to friend. Turned it back on and it would not move, forward or backward. Loader, PTO, and accessory...
You needb to drain the hydrolic fluid and then remove the suction tubethat comes from the right side of the engine and attaches to the hydrolic pump.Loosen the hose clamps and seperate the hose from the tube.Now go under the tractor and remove the brace that goes to the deck.Then go further under the tractor and take the last bolts out of the suction tube.Now you can remove the suction screen and clean it with some solvent and put it back in.Put your tractor back together,install a new hydrolic filter and top up the hydrolic oil,it should move.
Dec 05, 2009 | John Deere 4020 Gas & Diesel Tractor...
My John Deer 1020 turns fine to the left but when turning to the right the power sterring does not work. It seems to me an intermittant problems. Occasionally the sterring is fine but most of the time it...
open hood to get to top steering gear check for lube and check adjuster worm gear known to crack or break a gear tooth than check thru view plate opposite of the steering cylinder which is connected to the rack&pinion make sure timing marks line up may have skipped a tooth or the thrust pad(shims) have shifted
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Apr 03, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
687 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
