Question about LG 32LH30 32 in. LCD HDTV
White screen on TV.
I was in process of reprogramming Direct TV universal remote, I was inputting codes so I could get my TV to be on one remote when my LG 32LH30 just went white. Won't turn off or on, I have unplugged tv and left off and when plugged back in it goes right back to white screen and it shows a screen on top that says Power Only V04.52.00. My regular remote for tv will not work to turn off and on. I also reset the Direct TV remote which did not help with anything either. Please help.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
Posted on Apr 23, 2011
  • Gary B
    Gary B Apr 18, 2014
    I hit the Q.Menu button and held it then I held the back button. One of them worked.
    New Friend:
I have the smaller version of this LG TV and it did the same, just went to a blank white screen when I switched it on. Being very close to paying for it to be repaired or even buying a new one cause that's sometimes easier and cheaper! I decided to try look for a solution online and found this. Although the 'return' button didn't work for me I found the 'Q. View' button did so I recommend if neither of those buttons work simply press all the buttons on the remote or even press and hold. Hope this works, good luck!
Posted on Dec 16, 2012
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Televison & Video
The LED light was flashing (the remote was already programmed someone else programmed it for me) so I took out the battery and now I need to reprogram it. The instructions are in very tiny print and I
First you need to find the program button or input button. Almost all universal remotes are the same process for programing.Aim the remote at the tv and push the tv device button once then use the program or input button push and hold till the light blinks twice or stays on then put in your 3 or 4 digit code and press enter.
Jan 20, 2013 | Televison & Video
Reprogram the URC-9910 universal remote for VIZIO E3D420VX
Universal remote code to check with Vizio TV is [0081.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
Dec 30, 2012 | One For All URC-9910 LCD Remote Control
DIRECT TV codes missing for sharper image universal remote
Here is a link that can show you the process,www.directtv-advisor.com/direct-tv-remote-code. hope this helps..
Mar 27, 2010 | Televison & Video
Maxent MX-42VM10 42 Remote
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
Content Provider/Most commonly used code
Comcast: 1755
Comcast (ML-3251HLT Model): 0054
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Adelphia: 0156, 1755
Universal: 0762
One4All: 0036
Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
May 15, 2008 | Maxent MX-42VM 42 in. Plasma HDTV
Genesis mx-900
I have the same remote and need to reprogram the remote too.
Genesis X900 has anyone had any luck finding out how to reprogram this remote yet?
May 04, 2008 | Universal Remote Control DIRECTV Universal...
Sentry really big universal remote
Request Information by sooky, posted on Jan 12, 2008 Does anyone know the codes for a Vizio LCD TV?
The code to use is LG 1292...these other two have worked for others as well...0178 or 0030. good luck
Dec 28, 2007 | Zenith DBZN-311 Remote Control
One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Dec 27, 2007 | One For All URC-3021 Remote Control
LG 32LH30 32 in. LCD HDTV Logo
3,079 people viewed this question
Computer Repairing
Computer Repairing
