Question about Garden
Primer bulb is cracked on my Homelite Blower/VAC Model HB-180 Gas is leaking, I need replacement parts. Blower purchased in 1990
  • 3 Answers
Www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Posted on Apr 30, 2010
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
My primer bulb cracked, can I replace it?
Yes, in fact event he DIY centers have parts like that available off the shelf or ACE Hardware. You will need the specific model number to ensure you get the right part or bring the old part with you.
Jun 03, 2010 | Homelite Consumer Products Backpack...
Is it possible to replace a primer bulb on a homelite blower?
The bulb repair kit can be purchased a home depot or lowes, or whatever is close to your home. These can be replaced fairly easy. It is usually prongs on the backside that hold the bulb in. After pressing these the bulb will come out of the housing and disconnect the tubing from the bulb. It a good idea to replace tubing when doing this, the tubing is rotted or dried out and eventually cracks. Keep in mind where the tubing goes. One will feed from the gas tank and the other will feed the carb.
Mar 24, 2010 | Homelite Consumer Products MightyLite...
Blower will not prime and start
Primer bulb has hole in it or fuel line cracked.First use needle nose pliers to crimp fuel line just before primer ,dont use to much pressure and see if bulb will hold vacuum when you press it.If it wont hold vac either buld has hole or valve in primer is defective.If it does then you need to crimp off fuel line feeding carb and see if primer holds vac.If it does not then you need to replace powervalve inside carb.
Nov 16, 2009 | Homelite Garden
Blower
You need to rebuild the carburetor. Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then under select OEM select Homelite then do as instructed. You should find the parts you need and hopefully the parts breakdown for the carb. this will help you in the rebuild. If it does not have the parts breakdown for the carb. find what mfg and model carb. it is then go to that site for breakdown.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite hb 180 leaf blower
Changed all major gaskets: Cylinder to crankcase, case half, exhaust & carb. Now it runns right. The carb can be adjusted and the choke is full open when warmed up as it's supposed to be.
Gaskets ca be bought from Homelite directly at http://www.homelite.com/service_support/order_parts
Enter the model numbers & see the exploded views. Torque values are provided in the parts lists.
Nov 01, 2008 | Garden
Garden Logo
1,726 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
