Question about Samsung LN-S4051D 40 in. LCD Television
I have a 40 inch 4051 that we recently replaced the capacitors on, now the tv turns on for a little while and the I have no picture. I still have sound, Popped the back off there are no popped capacitors, any clue
    Scholar:
  • 56 Answers
Now the main control board is defective due to the faulty PS board and needs to be replaced.
Posted on Jun 01, 2010
Samsung tv takes many attempts to get picture to work
Possibly capacitors failing to charge up fast enough.
May 10, 2013 | Samsung Lnt4053h 40-inch Lcd Hdtv
No picture or sound just blue pwr light on apex 40 inch LCD what's going on?
first place to begin is if able test voltages in and out of the power board inside the set---if not able to do that consider having a shop look at it.
If you get it open:
Aug 26, 2012 | Apex Digital LD4088 LCD TV
I have a Sharp 36F-630 36" TV. Recently, it started getting a "band" across the top of the screen. It gets smaller as the tv warms up. It used to go away completely. Now it goes from...
You have a swollen capacitors in the vertical section try to replace all the leaky capacitors, you will notice that there is a liquid leaking out in the buttom of the capacitor.It is like an oil spill.
Dec 06, 2010 | Sharp 36F-630 36" TV
Not the capacitors, replaced in August.
Hi, sorry to hear you didn't prevail, i have been doing this for over 30 years and some still stump me... But you see, just changing the capacitors well seldom permanently "Fix" anything for very long. You see, those "Blown Capacitors" were a "SYMPTOM" and are a "RESULT" of some other problem, seldom these days for capacitors fault, Unless, they are overheated. To spontaneously fail. The thing that "Kills" Capacitors, is AC Ripple/Voltage, and Over-voltage. So you see you MUST first find why those conditions exist before you can even begin to replace anything Capacitors included. So as ALWAYS the first place we start is at the Power Supply, now you make sure those voltages are correct. and if they aren't find out what not, and what is causing the problem. Then, in that way you can isolate the fault and fix the cause at the same time. That way it is "Fixed" and not symptomatically treated. Also it is nearly impossible to do anything without a service manual, you MUST try to get one of those, they will also help you identify exactly what is wrong and where to look and what to do.
Mar 23, 2010 | Samsung LN-S4051D 40 in. LCD Television
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Oct 15, 2009 | Samsung LN-S4051D 40 in. LCD Television
Is there any High Voltage DANGER when repairing a Samsung LCD TV
Just be careful around capacitors, which could possibly still hold a charge. Otherwise, there are warnings on parts that you shouldn't touch. I would say that the biggest thing to watch out for is getting stabbed by the sharp solder points. I always forget how much it can cut you.
Aug 10, 2009 | Samsung LN-S4051D 40 in. LCD Television
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Samsung LN-S4051D 40 in. LCD Television Logo
130 people viewed this question
Jerry Greenberg
Jerry Greenberg
