Question about Radio Communications
My Motorolla GP 68 changes to a differant freq. when the PTT is pressed?
    Problem Solver:
  • 24 Answers
You have ON the frequency shift in your GP Motorola
Posted on Apr 25, 2010
Cant sync radios
The MU21CV radio is user programmable. Hold in the PTT button while turning on the radio. It will announce the frequency. Use the PTT button to count it up to the frequency you desire. Press the smaller monitor button to lock in your freq. Then the radio will announce the code number. Once again using the PTT button count it up to your desired code or the word OFF if you are not wanting a code. Then press the monitor button to lock in the code. At this point you can turn off the radio and turn it back on normally (without holding in the PTT). Your radios should be programmed to match one another. If you are still having trouble you may have a radio which needs repair or a bad/low battery.
Best regards.
Aug 05, 2013 | Motorola MU21CV (1 Channel) 2-Way Radio
Unable to transmit
The CTCSS codes are probably not set correctly. Baofeng manuals are notoriously hard to read. Look online (Google) alternative programming instructions.
Jun 09, 2013 | Radio Communications
How to program channel on motorola xv2100
Here is a link to the user guide, the instructions for getting into programming mode begin on page 18: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
A synopsis:
1) Hold in the PTT button and MON button while turning on the radio.
2) Press the MENU button one time. This will display your freq in the upper right. Use the plus or minus buttons to change the number. Press the menu button to lock in your slection.
3) The next number is your Code. Use the same method to select your code and lock it in.
4) Continue through the menu, pressing one at a time, making your selections according to the user guide. When you are at the end of programming you will hear a different chirp. When this occurs, shut off the radio and turn it back on normally. You are done.
Best regards.
Jan 09, 2013 | Motorola XV2100 (1 Channel) 2-Way Radio
I have a motorola mv11c and it works fine and I just purchased a pair of motorola mv21cv. They must be on a different frequency my question is how do I change the frequence on my mv21cv radios to be...
Hold in the PTT button while you turn on the radio. It will announce the frequency number. You can use the PTT button to change the number. Then press the Monitor (small possibly red) button to lock in your setting. The next number your radio announces will be the Code. Use the same method to change the code if needed. Then press the Monitor button to lock in your setting. Once you have set both your freq and code you can turn the radio off, then turn back on normally and use the radios.
Best regards.
Jul 22, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
I would like to change the frequency on my XU2100 to frequency #6 so that it receives tran smissions from our other 2-way in our community watch. If we leave them on scan they do work, but we would like to...
Hold the PTT button and the MON button in while turning on the radio. Continue to hold them until the programming initialization noises stop. Press the menu button one time to get to the Freq setting, change it to 6. Then press the menu button to lock in this setting. The next menu screen is the Code, set it to match your other units. Then press the menu button again to lock it in. Press the menu button to walk through another 2 or 3 screens and then you will hear a different chirp. Your radio is now programmed, simply shut it off and turn it back on and your radios should work.
Best regards.
Jul 22, 2011 | Motorola XU2100 (1 Channel) 2-Way Radio
I have three walkie talkies... Motorala CLS 1110... 2 of them are on FREQ 3 and the other is on FREQ 2.... how to i change the one on FREQ 2 to FREQ 3???
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Dec 23, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How could i program/change the freq of my motorola gp2000 manually
I don't think that you could program/change the freq of your Motorola GP2000 manually since newer Motorola radios today everything is done by computer and programming sotfware. You need to have software for GP2000, radio interface box ( RIB) and programming cable for GP2000 radio and these devices are not cheap. The best way is to contact a local repair shop to have it done for you or find a two-way radio technician, he could do this if he has all the test equipments required.
Radcom907
Oct 21, 2010 | Motorola GP300 Compatible 2 Way Radio...
How do i change the frequency and or channel
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
The instructions for getting into programming mode are on page 18. A synopsis is this:
1) Hold in the PTT button and the MON button while turning on the radio. Continue to hold them in until the radio is no longer making noise.
2) Press the Menu button one time. This is your Freq. Use the plus or minus button to change the freq. Press the menu button to lock in your selection.
4) Continue through the menu, making your selections according to the user guide. When you are at the end of the programming cycle the radio will emit a different chirp. When this occurs, shut of the radio and turn it back on normally. You are done programming.
Best regards.
Feb 24, 2010 | Motorola XV1100 (1 Channel) 2-Way Radio
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Motorola walkie
With the radio turned off, hold in the PTT and the Monitor button at the same time. Continue to hold these in while turning the radio on. Wait for the radio to finish making sounds before releasing the PTT and monitor button. Then simply press the menu button to walk through programming each of the features. When you have reached the end of the user programmable features you will notice the radio has a different chirp to signal you are done. Then simply turn off the radio to leave programming mode.
Oct 26, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
