Question about Maytag PYE2300AY Electric Dryer
Not drying efficiently. Seems warm inside but clothes are not dring as usual
    Habit-Forming:
  • 120 Answers
Good be clog vent are the heat element need replace
Posted on Apr 25, 2010
My Bosch dryer never seems to get very warm.It's an Axxis. I've only washed about 10 loads. It seems to take a long time, and when I take the clothes out, they are cool to the touch. Even when I touch the...
There are a few possibilities here:
1. Washer/dryers generally take longer to dry clothes than a stand-alone dryer so if you previously had a stand-alone and are now using a combi, this could be the reason.
2. There are usually at least 2 heat settings on a dryer, so maybe you have it on a cool setting?
3. The last part of a drying cycle (5-10 minutes) is usually cool - even when on a high setting. This helps to reduce creasing and cools metal parts such as zips and buckles for saftey. This could explain why everything feels cool when you remove the clothes.
It's possible your old dryer didn't have the cool final setting and/or it was higher power than your new Bosch and therefore dried the clothes quicker.
If your new machine is taking an eternity and your clothes still aren't properly dry, then there may be a fault with your dryer thermostat which is switching the heating coil/element off at too low a temperature. However, I suspect your problem is related to information I've written above.
It would help to know whether you have an Axxis washer/dryer or just a dryer. If the information above doesn't help you to solve your problem, please post back with details of your machine, including the model number, if possible.
Regards,
BElectric.
Nov 25, 2010 | Bosch Dryers
Dryer is not getting as hot taking longer to dry clothes.FRIGIDAIRE MODEL GLER341AS2.
If your dryer is STILL heating, but your dryer is showing signs of heavy condensation or longer dry times, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. As the dryer exhausts, moisture from your clothing is circulated with the warm air. If you have any restrictions in the exhaust system, the moisture will collect inside the ducting and drum. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If you do determine you have an internal component problem, the next link can give you some helpful advice on how to troubleshoot a dryer with a no heat problem: http://www.fixya.com/support/r3574266-thorough_dryer_advice http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat If you have any questions, please post back and let me know. I hope you find this information helpful.
Sep 15, 2010 | Frigidaire GLER341A Electric Dryer
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is slow to dry clothes, takes 2-3 cycles of 45-50 mins.
Check to see if there is a built up of lint in the exhaust.
Keeping the correct temperature at all times inside the dryer ensures that the clothes will dry efficiently. If clothes are not drying then inspect the door seal for signs that it may be worn or damaged.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit. A loose blower wheel will usually make a rumbling noise as well. Inspect the blower wheel to make sure that it is tight to the motor shaft.
Apr 19, 2017 | Whirlpool Dryers
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
Not dring
The air is not getting out of the dryer. Your vent hose is crimped or cloged or the flapper outside the house is stuck.. Air is not getting out of the dryer thru the vent for what ever reason.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
