Question about Canon PIXMA MP530 All-In-One InkJet Printer
Will not print or fax error 6a00 check printer
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I had the fatal 6A00 error on my out-of-warranty MP830 and I was ready to give up and buy a different printer. Per Canon website it says that you need to send it for repairs.
Goggling the error message, I was able to find a solution to this error that doesn't require sending the unit to Canon. . The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
Based on the postings, there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere. 2) there may some paper stuck somewhere around the printhead and or the purge unit or 3) there is a build up of gooey ink on the purge unit.
The gooey ink turned out to be my problem and apparently quite a few others. Following someone else's advice, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. I also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, I plug the unit back in and worked fine. Problem solved!
Posted on Mar 29, 2008
SOURCE: Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Posted on Jul 24, 2008
  • 240 Answers
SOURCE: Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on May 19, 2009
  • 3422 Answers
SOURCE: Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
Posted on Aug 13, 2009
pineworks
  • 4041 Answers
SOURCE: MP530 - Check Printer - 6A00 error
Hi
Hope it will work for you
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Feb 10, 2010
Action to fix Error Code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
6A00 found paper in place where cartridges sit and wait for a print job. Cleared the paper but still won't start. I have checked in all other possible places and no paper or scrap of paper to be found. Is...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Mar 07, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error 6A00 appears. Will not print. Cannot find
Try it maybe
Solution 1:
Solution 2:
Solution 3:
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00 print head not moving. Sometimes
Solution 1:
Solution 2:
Solution 3:
Nov 18, 2009 | Canon PIXMA MP960 Printer
Suddenly got an alrm flashing light, nothing works, no copy, no print, no fax. Error code 6A00
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
245 people viewed this question
old marine
old marine
