Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Jd gator overheating
Just started smoking from the top of the radiator, thought at first the water pump, or clogged radiator. To check the thermostat I removed thermostat and ran without it. No change. Flushed radiator, and checked to make sure fluid was moving through the water pump. Next noticed that the battery was dead also. Figured a short somewhere was affecting both the cooling system and battery. Contacted JD mechanic for advice. He thought maybe the relay was dead.(the fan to cool the radiator was not turning on.) Tried new relay with no avail. Now think it may be themperature sensor. Can these short out and do you suggest any more tests? Thanks a million.
    Habit-Forming:
    New Friend:
  • 21 Answers
My thought is that you may have a burned out temperature sensor on your radiator. You can find this by simply looking for a plug on the radiator that has a wire chassis connected to it. these things can burn out rather easy and it could have been effected by being hit by debris or other objects that could have caused the sensor to short out. Replace the temp sensor. Usually located near or at the bottom of the radiator. Hope this helps.
Posted on Apr 05, 2017
5 Suggested Answers
SOURCE: My jd stx38 riding mower doesn't go forward or reverse after I re
Check the drive belt but if this is a hydro you probly have a bad trans. Best bet get a new mower.
Posted on Jan 08, 2010
wireguy212
  • 1627 Answers
SOURCE: 6330 JD every fuel line leaks with just over 100 hours.
John Deere will replace the lines with the original under warranty but as soon as your warranty runs out and you develop a leak go to solid rubber after market fuel lines and your problems will be over.The braided fuel line that is put on at the factory and replaced by Deere under warranty has a poor performance record and i would replace it,Deere can't get warranty for the repair unless the part replaced has a J.D. part number on it,but if you are willing to supply the hose,go rubber and the leaking will end.
Posted on Apr 15, 2010
SOURCE: I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Posted on Mar 21, 2011
BAMOUT
  • 2478 Answers
SOURCE: leaking jd gator thermostat housing
I would fix it. Put a new gasket on thermstat housing.
Posted on Sep 16, 2012
Why wouldn't water circulate through the radiator
You are spot on. Bad water pump. It is also probably the reason your timing belt was frayed. The water pumps of later model cars usually drip some through a "weep" hole in the bottom when they are going out as a kind of warning "Hey, you gotta get me a replacement soon!" But unless you live where no air conditioner is ever needed, or used, most people think it is the drippings from the AC. Get that pump replaced ASAP and when done, do a compression check on all your cylinders to make sure there was no head gasket damage from overheating. Good luck.
Apr 22, 2014 | Kia Sportage Cars & Trucks
Engine overheating
check for water coolant circulation. either you might have a clogged radiator or faulty water pump. to check the radiator after you run the engine for a while switch it off and try to find an easy access to radiator vents and touch all surface to see whether is all ho or if is some,then you remove it and send it for cleaning. as regards water pump,take the thermostat out put water in and start the engine follow the water circulation when you rev.if it rotates the water pump is working if is steady and coming upwards to over flow then the water pump is faulty. Also the other possibility is the matrix to be clogged..
Aug 30, 2012 | 1996 Ford Taurus
I keep overheating changed out thermostat and fan and still overheating I fill the hose with coolant and it all goes into the overfill tank and gets hot and boils out
A clogged radiator could be your problem. Flushing won't necessarily clean out a clogged radiator.
When it's idling and getting hot, the clutch fan should be running full on, actually "roaring" as some say, and the electric auxiliary fan or fans should be on if you have them. Also test your radiator cap, replace if needed. Hope this helps.
Jul 03, 2011 | 2003 Dodge Durango
Engine overheating - temp gauge almost to h. what are possible problems. fboth frt cooling fans are operating
Any clogged cooling hose water, bad water pump or clogged radiator. Are you check any leak of coolant or white smoke from exhauts?
Aug 06, 2010 | 2006 Infiniti G35
My chevy is overheating with no smoke
No smoke good cooling system is sealed, could be a thermostat, sticking or radiator fan not coming on, does it start to over heat at stops or low speeds, if so have your radiator fan check out, if it over heats at any speed, replace thermostat and check coolant level.
Jul 10, 2010 | 2000 Chevrolet Impala
It overheated, smoking and water pouring
If water poured out you probably busted a hose or radiator sprung a leak. Sounds like that and a bad thermostat or water pump went out.
May 10, 2010 | 1991 Buick Century
I have a 1997 olds siloutte that is overheating
clean and degreese the engine from the top to the bottom. fill the radiator and start the van let it idle for at least 20 min and look for a leak. if no leak present look at the tail pipe smoke. if smoke is white you have a bad head gasket. Also check oil to see if it"s milky
Jan 01, 2010 | 1997 Oldsmobile Silhouette
Radiator overheating
The only thing missing from your narration is the water pump. Check to make sure that you are not losing coolant from the water pump. Make sure it is not leaking coolant. If there is evidence of leaking, the water pump is bad. You must take extreme caution when dealing with the cooling system (hot liquid under pressure; not a pleasant thought), but you can remove the radiator cap and start the engine. Check the coolant in the radiator for movement/circulation. If the water pump is functioning properly, there should be some visible sign of water/coolant circulation. The water pump may not be at fault, but with the other upgrades you made to the cooling system, some gunk (for lack of a better word) may have broken loose and clogged the ports in the water hose. You can also remove the hose at the water pump and check for anything clogging up the works. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | 1992 Chevrolet S-10
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
5,211 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
