Question about American Standard Plumbing
Tighten the spray assesory on the kitchen sink. It is diffficult ( impossible) to tighten because of its location beneath the sink. Common tooks are not up to the task, Finger tightening is not adequate.
  • 5,603 Answers
You MAY need a "basin wrench" which has a long bar and an end that grabs like a Stilson wrench.
A site with pix:
http://www.amazon.com/Cobra-Prod-PST151-Adjustable-Wrench/dp/B001B00LCA
Posted on Apr 24, 2010
Kitchen faucet
You will need a basen wrench ( a special wrench to tighten nuts that secure faucet to sink) and open end wrenches. First shut off both hot and cold water valves. Using open end wrench, disconnect hoses from valves. Now, you must loosen both nuts (under the sink towards back wall) Using the basen wrench. After removing nuts, lift faucet up
Jan 09, 2014 | Plumbing
I am attempting to install a new Danco P-Trap beneath one of my bathroom sinks. My frustrating problem is I am unable to screw the pvc drain pipe to the U joint. The gasket that comes with the kit makes it...
Assemble the hardest part first, but don't tighten it up. Connect the other parts, but don't tighten. Go back to your hardest piece and tighten. Then tighten the remainder.
Best regards, W/D
Jan 29, 2011 | Danco Plumbing
When i move the spout sideways, the whole fixture turns instead
You need to tighten retaining nut on the underside of sink. You will probably need someone to hold faucet steady while you tighten nut. Yom may be able to use channel lock pliersor adjustable wrench. They can be hard to get to as there is not much room. If you have to you can get a basin wrench at most hardware stores. Usually around $15.00. The head will turn from 90 degrees on one side to 90 degrees on other. To use turn head so that open end of jaws are pointing to your right if you are laying on your back under sink.Open jaws and put around retaing nut and turn counterclockwise. This will tighten jaws around nut and you should be able to tighten nut. If you need to you can apply penetrating fluid on threads and get it to tighten. Hope this helps. Thanks
Nov 14, 2010 | Kohler K-10416-BN Fort½ Single Control...
The base of the faucet which fastens to the top of the granite is loose and moves around. Is there a nut under the faucet that tightens to keep it firm to the granite? How do I fix this?
yes there is, with a pair of slip joints you can tighten from underneath, it is above the supply line, the best thing to do is turn off the water, disconnect the supply line and tighten the nut, then reconnect the supply line and turn back on the water. Good Luck Tim
Oct 31, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
The pullout spout leaks
pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Jun 28, 2009 | Kohler K-15160-7 Coralais single-control...
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Plumbing Logo
59 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
