Question about Garden
Adjust carburetor won't start, or if it does won't idle.
    Brigadier General:
  • 4,088 Answers
Before adjusting anything, check the condition of factors that pertain to the proper running as: fresh fuel mix, plugged fuel filter, air cleaner, and muffler. Poor fuel lines, and loose carburetor fasteners. Remove the spark plug, and place it on engine metal (wire attached). Pull the engine through smartly--the spark should be blue and snappy. Plug gap should be ~0.020" and the insulator should be light to medium tan in color. Try a new plug if in doubt. When these things appear to be correct, turn both jet screws CW to stops (lightly), and then CCW each back out 1-1/2 turns. It should start and run fairly well at this point. Allow the engine to warm up, pull the throttle full on. The engine should be 4-stroking--turn H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly smoothly, yet allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine doesn't stall out. If you can't get the above to work, you may need to clean and re-kit the carburetor first. Hope this helps!
Posted on Apr 29, 2010
Vf750 honda idles but dies when throttle opened
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts choke but dies with little throttle
1984 VF700 Magna starts but won take throttle
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Jun 14, 2014 | 1995 Honda VF 750 C Magna
Sanben Zoom II will not idle
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
scooter starts but will not stay running Scooter Doc Forum
Scooter won hold idle dies
Scooter Carburetor Adjustment Scooter Focus All about Scooters http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Oct 27, 2017 | Motorcycles
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
Poulan Saw
There should be an idle screw on th carburetor labeled H and L for High speed idle and Low speed idle, adjust the screw to where it'll run....
I hope this helps....
May 16, 2013 | Garden
1997 Kawasaki KDX 200 dies with throttle
Hi, Natasha and the usual suspects are:
16. Faulty fuel pump or internal fuel line has pinholes.
17. Fuel injectors clogged or faulty.
18. Faulty throttle position sensor.
Bike idles perfect but dies when given the slightest amount of throttle 93...
KDXRIDER NET View topic KDX220 won run right
Kawasaki KDX200 Service Manual
OEM Parts for Kawasaki
1998 Kawasaki KDX200 Owner Manual
Dec 16, 2012 | 1998 kawasaki KDX 200
Yamaha pw 80 wont idle
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha pw80 wont stay running
1989 Yamaha pw80 won idle
YAMAHA PW80 Owner Service Manual
OEM parts for Yamaha
YAMAHA PW80 Owner Manual
Oct 21, 2012 | Yamaha PW 80 Motorcycles
2006 Honda VTX 1800 will not idle
Hi, Jeff and the usual suspects are:
13. Multi carburetors not in sync.
2003 VTX 1800 won idle
Bike won idle
Honda VTX1800R Owner Manual service manual, not owners
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2005 VTX1800C Owner Manual
May 06, 2012 | 2006 Honda VTX 1800
1996 sportsman 400 wont idle. Had the carb cleaned by a "mechanic" after the bike took off wide open and driver was injured. He said the float stuck and he "fixed" the problem. Now...
I have NEVER heard of a float sticking and causing that issue. Sounds to me like the Electronic Throttle Control (ETC) on the right handlebar isn't or wasn't adjusted. There is a thumb nut on the throttle cable coming out of the ETC switch. Loosen the screw and turn the cable in or out to get 1/16 to 1/8 inch freeplay on the thumb throttle. Too loose and it won't idle, too tight and it will pull the throttle cable tight and rev engine. It could also be a carburetor issue if it runs with choke. Either the idle screw isn't adjusted or the pilot jet is plugged. There is a large thumb screw coming off the carburetor, turning clockwise will turn the idle up. Let me know if you need anything else, Daniel.
Sep 18, 2011 | Polaris ATV
1986 Yamaha FZ750 - engine will start and idle - won't rev up. (engine quits)
Hi, Carefree22 and the usual suspects are:
Bayou 300 idles but won rev
my bike starts runs idles perfectly but will not rev
1985 1988 YAMAHA Genesis FZ750 Service Manual Repair Manuals AND Owners... $10
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Sep 20, 2010 | 1986 Yamaha FZ 750 TV (Europe)
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
