Question about Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than blank. 4.Dell e1724FPB Power button flashes, No display 5.Dell e1724fpb power Button Flashes, no display 6. Hyundai L70N Gets video for a little bit, then goes out, and nothing works again. 7.Hyundai L70S Power Light Flashes. 8.Acer AL1716 No Power. 9. Hp VS17E Comes on, THan goes off. 10.Hp VS17E. Display works, But has streaks of color, You cannot see icons or anything. Any help would be appreciated.
  • 11,361 Answers
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Posted on Apr 25, 2010
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen is blank
Those models are made by BenQ. Their notariety is bad solder connections that cause the drive transistors to overheat. Sometimes it just blows fuse pf751(2 amp); other times it will damage a transistor or two (2sc5707 or 5706 x 4).
Be sure to resolder the output transformer leads.
Monitor Mike
Mar 16, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Thanks
proton
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor Goes Blank after 30 mins....
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Dec 12, 2006 | Dell E173FPb 17" TFT LCD Monitor
Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor Logo
587 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
