Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Paper in tray and I keep getting a message out of paper
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
I am trying to print a document and it keeps telling me to load paper
Hi
Turn it off and disconnect it from PC and from power.Reboot the PC.
Connect the printer again and try to print.
Look through the paper tray for any obstructions.
Feb 21, 2012 | HP Photosmart C7280 Printer
Keep getting misfed paper message. can't see paper
Check the paper tray. The part at the end of the paper might not be keeping the paper pushed to the front of the tray. Remove the tray and check the rollers that feeds the paper. They might be slick. Clean them with some WD-40 sprayed on a rag.
Nov 22, 2009 | Ricoh CL4000DN Laser Printer
Paper want go in to print
The reason why it keeps saying this is cuz you paper feed tire needs replacing. Now i am not sure based on the cost of this unit if it would be worth to have this repaired but, this is what is causing this error.
Jul 24, 2009 | Lexmark X7170 All-In-One InkJet Printer
Won't print
The printer is giving that message as the print job sent to the printer is asking for the correct paper type. Check the program you used and its print setup in that program to make sure the correct paper is selected. Software overrides hardware settings on a printer.Another thing is double check the tray position tab and make sure it is set to letter and locked in that position. If the paper tray is not set it can also think that the paper in the tray is a different paper size.
Bruce
Jul 15, 2009 | Dell M5200n Laser Printer
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Paper won't pick up from the paper tray. I keep getting a load error message or paper tray message no matter how I load the paper. I get the codes "A4" and "024-964" Thanks
Check your printer for paper size and type settings. Ensure they are set to letter and plain1. Also check the program you are printing from (Word, wordperfect, etc) and ensure the paper size is correct there as well.
Feb 25, 2009 | Dell 3100cn Laser Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
213 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
