Question about Maytag MSD2454G Side by Side Refrigerator
Freezer & refrigerator are not getting cold.
Unit is 7 years old. Items in freezer are thawing; milk in fridge is spoiling. Turned temp up to 7 with no change. There is no air coming from vents inside unit. Removed back of unit and cleaned out dust, etc. - wasn't very dirty.
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerFreezer & refrigerator are not getting cold. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 25, 2010
I noticed a couple weeks ago the frig side was not cold enough. Milk spoiling but butter not getting soft. Freezer side seemed to be working ok. Now Ice cream in freezer is getting soft.
How old is the fridge? Most units have a system of tubing attached to metal fins, which is located in the back of the unit. This tubing & fins must be kept clean as dust will accumelate & insulate the freon gas from turning into a liquid.. Another problem is when the motor & compressor does NOT get enough air to cool the tubing & fins. This happens when the refrigerator is located in a closet type atmosphere where the unit is too big to get any air to the rear of the unit. NO spacing on the sides or top. ALSO, the compressor might of died. In this case, if the unit is out of warranty and/or over 7-15 years old, buy another, NOT worth the repair. If still under warranty, call vendor/manufacture.
Louie Almond
Mar 27, 2011 | Refrigerators
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Milk and other items keep freezing in my side by side fridigaire
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS23H5AS Side by Side...
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Refrigerator to warm freezer OK
first check the fan...make sure it is running.
next defrost the freezer unplug and open the doors untill all the frost is gone about 24hrs at room temp..
plug it back in and see it it will work better ..if it does you have a defrost problem... let me know
Nov 12, 2008 | Frigidaire Refrigerators
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Maytag MSD2454G Side by Side Refrigerator Logo
107 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
