A cleared bios
I have accidentally cleared my BIOS I do want a way to restore it back, becos the PC is no more responding.
  • JACOSPA Mar 23, 2008
    my machine is fujitsu siemens lifebook e series
    product No. FPC07090B
    SERIAL No. YBFP07006
    Genius:
  • 3,587 Answers
Well..you'll need to install if from a floppy or cd, from a download..check the maker of your computer, and find what bios they use. then download that to a cd, insert it into the computer that's not working, and then follow those instructions.
Posted on Mar 23, 2008
  • Patrick Michaels
    Patrick Michaels Mar 23, 2008
    well.now that you have that, go to this site, and get the bios from them..on a cd on the system you are using to communicate with me..and change the rating according to the 'finish' of this conversation, please
SOURCE:
My hp desktop computer was working well but after a lightning, it is able to boot with no usb port responding and it does not have a ps2 mouse or keyboard connector. What should i do?
pls clear cmos jumper first. after power on and go to bios by press the key board key. if worked, pls check the O/S setup or recovery setup . pls select select system restore and press restore previous date.
if not working usb key board and install PCI or PCI X usb adapter and plug to key board and mouse to it and go to bios and disable on board usb controller.
go to O/S and check
Jan 04, 2017 | HP Computers & Internet
I was flashing a new BIOS to my ASUS M2NPV-VM motherboard, when the PC hung whilst rebooting. I had no option but to cut the juice, and now the PC won't boot; won't even get to BIOS/post. HELP
Your motherboard has a CrashFree Bios2 feature that only supports the VGA output (not DVI). If you connect your monitor to the VGA port and see nothing then you should disconnect power and move the Cmos Ram jumper to Clear position for a few seconds and then restore to the operating position. Then restore power and see if you can enter Bios Setup. If this restores you to a default bios, do not upgrade again until you are certain that the bios version is correct for your chipset, bios manufacturer, etc.
Sep 19, 2011 | ASUS M2NPV-VM Motherboard
How to cmos clear of dell model m1330
There are two ways you can restore the CMOS/BIOS back to the factory default.
First, turn off the laptop and remove the BIOS battery for 15 mins.
Insert the BIOS battery back again and go into the BIOS configuration to set the Date and Time etc.
Second, go into the BIOS configuration press the f1 or F2 or F10 key (not sure which key for your model DELL). When you get into the BIOS then there is a setting to restore the BIOS to the default, then save setting and exit.
Nov 19, 2009 | Dell XPS M1330 Laptop
I have a MCP61SM-GM motherboard and I accidentally flashed the wrong BIOS. I need the original BIOS but there are no websites around that have this! :(
Kindly try this link i provided you it directs you to the BIOS download for your motherboard. Kindly click the link below.:
Download MCP61SM BIOS
Kindly click the filename that contains the BIOS version of your motherboard.
Thanks
Jul 30, 2009 | Computers & Internet
BIOS password locked
Try to reset the CMOS using CMOS jumper reset. Look this in its manual how to do it.
Or take out the CMOS battery out of its socket then place it back again this should clear CMOS and restore to its default setting. Without the BIOS password.
Apr 14, 2009 | Computers & Internet
BIOS problem??
Open your case look on the motherboard find what looks like a big watch battery carefully remove the battery leave it out for about a minute and put it back in. This will clear CMOS and restore BIOS to factory settings. Hope this helps
Jan 30, 2009 | HP Computers & Internet
I want to restore my computer to its factory settings and i dont know the password. i bought the computer used i want to clear everything the former owner did
hi friend
u have to do this clear your bios password u have remove your pc bios battery for few mintes then u have to put it back your bios password has been clear
thnx for using fixya
Jul 08, 2008 | Acer Computers & Internet
How do I reset the cmos settings for the msi motherboard ms 6570?
If you're unable to enter your BIOS, or if you set a system password in the BIOS but forgot it, you might be able to fix the problem by clearing the CMOS memory. On some motherboards, this requires you to turn off and unplug your PC, disconnect the CMOS battery for a few hours, replace the battery, and turn on your PC again. Other motherboards have a CMOS clear jumper pin that you must move to a temporary position and then return it to its original position.
Post back if you still need more help.
Thank you
May 07, 2008 | MSI K7N2 (MS-6570) Motherboard
A cleared bios
hi
go to bios go to cmos setup set time details.
and go to boot option set first device to hdd.
then save settings restart sys
Mar 23, 2008 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Bios Password for Tecra M1
hi
go to your bios setup when it wants password press enter .thats all your password is disabled.
other way that clear your bios setup with help of jumper settings.
third way put your cmos away from its position for 15 min your bios is clear.
Mar 20, 2008 | Toshiba Satellite A135-S4427 Notebook
Open Questions:
Computers & Internet Logo
180 people viewed this question
Ekse
Alun Cox
