Question about Singer 7442 Mechanical Sewing Machine
Re-curring loose bobbin case
My mum bought me this machine brand new- and after a few hours of use the bobbin case is not sitting in the metal casing tightly, causing the thread to loop and bunch up around it, and on the underside of the fabric. I have tried re-threading it again and again, and taking the whole thing out and re-fitting it. It seems to stay put for 30 seconds of sewing then comes loose again. Is this something a Sewing Tech. can fix (permanently) or will it keep happening?
    Genius:
  • 1,116 Answers
According to the manual, this is a drop-in bobbin.
If the bobbin case came loose, the needle would probably hit it and brake.
Take the bobbin out.
Turn of the power and remove the needle plate (under the presser foot).
Raise the needle to it's highest position and lift out and reset the bobbin case into the shuttle. This should be in the maintenance section of the manual. The bobbin case should fit snug.
Make sure the thread is feeding from the bobbin, counter-clockwise and through the guides on the bobbin case.
For a rotary bobbin with a metal bobbin case.
Remove the bobbin case. Make sure the thread is feeding clock-wise and through the guide on the side of the bobbin case.
Raise the needle to it's highest position - this puts the hook at the lower left. Left the tab on the back of the bobbin case and slip the bobbin case back into the shuttle with the "arm" straight up. You may have to move the bobbin case a bit to the left or right for it to snap into place.
If the problem persits, take the machine back to the dealer - there should not be a charge for fixing this as it is brand new - keep your receipt and warranty information at hand.
Posted on Apr 24, 2010
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Jul 20, 2009 | Yamata FY700 Mechanical Sewing Machine
My Bernina 930's lower tension is off. When I sew the stitches are tight on top, but loose on the bottom. How can I fix this? I've tried messing with the tension and have cleaned the bottom.
Hi - you might have a dirty bobbin case, or need a new one. IAfter awhile, little teeny dust bunnies can collect in your bobbin case and cause your bobbin tension to go wonky, especially if you use cotton thread. If you happen to have an extra bobbin case, try using the new bobbin case to see if that solves the problem. Otherwise.....
  • Remove your bobbin case and take out the bobbin. Find a small, stiff brush like the one that came with your machine and stand in very good light. Brush out the inside of your bobbin case, and push one or two bristles of your brush into any opening you can see. If you see any trace of dust but you can't get it out, use tweezers to gently pull the dust out. Now look at the outside of your bobbin case. In the small opening where you insert your bobbin thread into the bobbin case, there is a small piece of metal with screws in it the lays over the bobbin case. Brush that area carefully, and again, insert one or two bristles under than piece of metal and into any other small opening where the bristles will fit. Try sewing again. If you are still getting loops, take out your bobbin case with the bobbin thread still inserted and grab the bobbin thread with two fingers. Let go of the bobbin case - sort of like you are holding a yo-yo. If the bobbin case starts to drop as soon as you let go, your bobbin tension is loose. If the the case doesn't move, gently snap the bobbin thread you are holding and see how far the bobbin case moves down toward the floor (you might need to try this a couple of times, the bobbin has a nasty habit of flying out). When you do the snap, the bobbin case should move down about two inches and stop. If do not know how to adjust the bobbin tension, either check your manual or take the machine in for service.
  • If you haven't already, it's a good idea to remove the thread plate that sits under the needle and clean that area out with your brush. Also, get a really good flashlight and check the area where you insert your bobbin case. Gently turn your fly wheel and look inside the hook area - remove any dust or bits of thread.
In general, you should oil your machine as indicated in your manual as often as directed. You should change your needle every 10 hours of sewing - or each time you start a new project, and you should take your machine in for service every one or two years - even if you only use it once and awhile.
Hope this helps, Ginny
Dec 06, 2008 | Kenmore 19365 Computerized Sewing Machine
Bobbin case
Get in touch with the whoever sold you wrong one to start with. If you still don't get the right one, try a dealer who sells that brand of machine.
Oct 23, 2008 | Singer 6038 Mechanical Sewing Machine
Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Jun 30, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
806 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
