Question about Jenn-Air Ovens
Jennair expressions double oven display blank but oven works model number ww304308 thanks for any help
SOURCE: oven gives code E6 F2 on panel
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Posted on Jan 26, 2008
SOURCE: dim display.
The display sits on a circuit board. Pull the board out and replace capacitor C3. It is 68 micro farads. I used a 47 from Radio Shack and it works great. If you can find a 68, that would be ok too, of course!
Posted on Nov 30, 2008
fixyourboard
  • 310 Answers
SOURCE: F2 E6 on Whirlpool RBD305PDS14 double wall oven
Sometimes we see an intermittent electrical connection due to oxidation of the contacts on the keypad membrane tail. This can be easily cleaned so you can check this before investing in a new keypad. I posted some pictures and the procedure on our website. Here's the link:
http://fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
Posted on Sep 20, 2009
  • 220 Answers
SOURCE: Jennair 30" wall oven display is totally off.
Part # 71003424 runs around $185.00
It's a common issue in Jen-air ovens,the display burns out,the control itself will still work fine but you just can't read it.
Posted on Sep 22, 2009
taran_2005
  • 10515 Answers
SOURCE: Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 20, 2009
Whirlpool double oven display reads E6 F2
I have a Whirlpool RBD275PRT00 that showed the same codes. it would allow me to cancel and work for a few more days until the display finally went blank and after a few days of being blank displayed the codes again. I ordered a New Electronic control board from Sears W10340941 for 189 dollars just recently, when I just looked for this part for your model it's that same number but now listed for 254. There are services that will repair your board for a little less but it will not be a new board. it's still much cheaper that a new oven.
Dec 02, 2013 | Whirlpool GBD307PRS Stainless Steel...
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
OVen display is blank and oven won't turn on. Oven has power (checked breaker, oven light works)
Can you supply a model number?
Most likley you have a bad erc control board ( clock). But a model number would help narrow it down.
Jan 02, 2011 | Whirlpool RBD275PD Electric Double Oven
Sep 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
CAN BARLEY READ THE DISPLAY
You need to replace the display backlight lamp.
Enter model number here to find assembly diagrams and parts.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Jenn-Air JJW8627C Expressions Collection...
Time and Temp. display on my JennAir Expressions is not working.
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Dec 31, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Dim display.
Oct 12, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Ovens Logo
65 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
