Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My dryer is squeaking like crazy. What is wrong
My dryer is squeaking like crazy. What is wrong with it?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 173 Answers
All dry have roller that the dry drum roll on an all so there a little wheel that the dry belt go around you may need to replave them are if you know have to take the dry apart an clean the lint out of the botton of your dry an if you left any item in your pocket you will find them in the botton of your dry make sure you unplug your dry b4 you work on it ok
Posted on Apr 25, 2010
Kenmore elite quitepak 9 dryer is squeaking
What kind of vent piping are you using? The wrong vent pipe can cause the wheel over the heat element to overheat and squeak. It is recommended that rigid metal vent pipe is used now a days.
Nov 24, 2012 | Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
I have a FP Electric Dryer DEGX1US and it is squeaking like crazy! Can you help?
more than Likely the rollers that hold the drum,, you have to remove the drum (be sure and look before to see how the belt tensioner is set up) pull the drum, Lube the rollers , and reassemble
Aug 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
GE washer squeaking
Make sure the felt on the rim of the drum is secure and the plastic glides that the drum sits on are not worn down.
Jul 27, 2010 | GE Dryers
Dryer squeaks like crazy.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer squeaks like crazy!! how do i fix?
replace front glides and rear bearing
Apr 25, 2010 | GE Profile DPSR475GW Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Squeaking sound on new samsung dv448aew dryer
first off you need to put your foot down and tell them to replace the belt or the adjuster .dont let them leave until they have satifyed you
Mar 24, 2009 | Samsung DV448AEE Electric Dryer
Bosch Dryer squeaking noise
I have not seen any service manuals online. The squeak will possibly be a rubber bush used to silence the machine. If you get it stripped down you should be able to locate the squeak by carefully applying pressure in different areas and the squeak should go... then hopefully you will have found the culprit.
Mar 15, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Jan 06, 2008 | Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
575 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
