Question about Panasonic Televison & Video
My dvd player in our 2004 nissan titan gives us an error ''disc format error'' (we've tried several different dvd's) and we have tried to clean it... Help!
nfandres
  • 168 Answers
SOURCE: "No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Posted on Feb 22, 2008
jamielwright
  • 75 Answers
SOURCE: DVD gives an invalid Disc Error
It's possible you have a bad DVD player unit and it will not read any type of DVD disks.I have had a lite on DVD player before and no matter what type of DVD I put in it.It wouldn't play.It only played CD
Posted on Jun 01, 2009
  • 4 Answers
SOURCE: recording error E4 54037380
This seems to be a common problem on all DVD players.
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Posted on Nov 11, 2009
SOURCE: Disc error
when i press play on my dvd/cd player it says error
Posted on Feb 01, 2010
SOURCE: LG HDD DVD recorder RH7521W is not able to read
Mine had a similar problem. I assumed there might be some dust on the laser. I used an air compressor and pointed it at the DVD slot as it was opening and closing to blow some air around inside the unit (and hopefully dislodge any dust). It worked. The discs that would not play before did play after. I didn't have the air compressor nozzle too close to the opening as I didn't want to dislodge anything I wasn't supposed to. If it was dust on the laser, you might be able to clean it in other ways, such as removing the cover and using a cotton tip (take power off first!). That would have been my approach if I didn't have an air compressor.
Posted on Feb 02, 2010
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
Why do dvd players say no disc when there is one in it?
This can be caused by several different things. It may be the read head assembly needs to be cleaned, the disc cannot be recognized. Or it could be a disc format which the player does not work with. Check the owner's manual for compatible disc formats. the Disc may be damaged or needs to be cleaned. The disc may need to be finalized by the recorder it was recorded on if a recordable disc. This is not the case for DVD-video as these are stamped discs.
You can try a cleaning disc but it may not solve the problem.
Inspect and clean the disc and try again.
Having the disc head assembly cleaned may be the answer but the service cost could be more than just buying a new player.
Mar 04, 2011 | Cyberhome CH-DVD 300 DVD Player
My Sony RDR-GX7 dvd recorder keeps giving me a "disc error" message every time I try to play a disc. How can I fix this?
Hard to say because this could be caused by any number of things. You could try cleaning the optical read head but this could get very involved unless you use a cleaning disc which may not work. You could try different discs such as a CD to see if that still fails. It could be the disc format. If everything fails then most likely a repair is required. Go to https://eservice.sony.com/webrma/web/index.do and locate a SONY repair location.
Aug 07, 2010 | Sony RDR-GX7 DVD Recorder
DISC ERROR
it could be a region problem. most dvd players are locked on certain region areas..like America being Zone 1 and S.A being Zone 2. imported or diffirent format of dvd's usualy gives a disk error message. if you think it might be region try www.videohelp.com. they give hacks for region problems^^
Mar 30, 2009 | Sony RDR-GX300 DVD Recorder
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
You could not format the disc due to error detection, whats wrong
You can get this if you´re using RAM-discs previously recorded/formatted on a different recorder. Clean the disc REALLY WELL and try inserting several times, it may pass.
Jan 06, 2009 | Samsung DVDR120 DVD Recorder
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
Formatting a disc
best solution is to return it. they are junk
Jan 03, 2008 | TruTech TT1620 DVD Recorder
Televison & Video Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
