Question about Sony DVP-NC600 Multi-disc DVD Player
My sony dvd dav-s800 player plays a dvd for a while then locks and says protected.......why is this? It never used to but we have a new flat screen tv?
  1. my home theater is Sony HCD-S800 is showing Protected in display what should i do
Posted on Aug 05, 2011
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Region code sony dav-tz140
sorry you fix yoy problem i have the same one
Jan 19, 2013 | Sony DAV-TZ140 DVD System
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
Oct 15, 2010 | Sony DAV-DX255 System
The DVD player will stop playing and the message
It is possible that your system is gettting overloaded and makes the sfety cicuit switch off . This is the protecction circuit to prevent further damage and fire within the system particularity when the output or power is shorted. Check from the speakers for short remove and test . Also use a multimeter to test for short in the output drive. If so disconnect and see if the protect releases. Then you must replace the outputs. Check also the protect cicuit for a false alarrm due to wrong biasing. Hope this advice helps to figure out. Good day
Jul 20, 2010 | Sony DAV-C450 System
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Dvd freezing
is ur dvd player in an inclosed area because they need air and some more than others. is the device getting hot to the tuch. if it is then put somthing under the corners of the dvd player to raise it up. this should stop it from over heating. also try cleaning it. please rate my suggestion. thanks
Feb 01, 2009 | Sony DAV-DX150 System
Picture distortion. Sound fine
Dont worry andysenny, Just give your dvd player for general service, these small problems will be rectified.
Feb 10, 2008 | Sony DAV-SC8 System
Help I am locked out ! Sony DAV S 550
Hold down the eject button for about 10 seconds
Sep 02, 2007 | Fisher DVD-SL30 DVD Player
Sony DVP-NC600 Multi-disc DVD Player Logo
264 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
