Question about LG LRFD25850 French Door Refrigerator
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
The shut off arm for the ice maker won't go back up and the ice maker does not make ice any more
Posted on Jun 08, 2010
  • 4,059 Answers
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Apr 24, 2010
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
I have a Samsung rs261mdrs side by side refrigerator. The ice maker quit working. I replaced the ice maker, it filled with water after a few hours I check for ice. It's frozen in the ice tray but won't...
Is it that the ice maker unit won't drop to the tray ? or the ice from the tray will not dispense trough the door? I need more clarification to try to help...thanks
Mar 04, 2015 | Samsung Refrigerators
Pim10bls
Possibly the water control valve is leaking when shut off, and water constantly drips into the ice tray fill tube. When this happens, the fill tube becomes clogged with ice, and the ice tray does not fill. The ice tray will cycle often, because there is no water in the tray, but will remain empty. If this is the case, the water control valve at the bottom rear of the refrigerator will have to be replaced.
Jul 31, 2014 | Polar PIM10BLS Portable Ice Maker
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Mar 19, 2011 | Refrigerators
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not getting water
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
Aug 17, 2009 | Whirlpool Freezers
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice Maker
The water valve appears to be the problem. The water valve ,located on rear of ref. at bottom has two (2) sides to it. One side feeds the water to the water dispensor and the other side feeds the ice maker..
Jul 07, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
LG LRFD25850 French Door Refrigerator Logo
664 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
