Question about Kenmore Washing Machines
My Kenmore washer model no. 110.49182990 will not come on. I have unplugged it and turned it off for about 30 sec. Nothing is working ... Help Please!
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.49182990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Other than the obvious, (does it have power to the washer) one of the leading causes for washers of this type not working is the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Apr 24, 2010
My kenmore elite front load washer is stuck at "control lock"...I press ad hold for 3 secs to unlock but nothing happens ... I also unplugged and plugged it back on but the light is still on and...
if this is a front load washer you can take off the lower panel and reach up on the right side and pull the cord that is attached to the door lock assembly another way would be to unplug the unit for ten minutes which would reset the control although reseting doesnt always work if you have an error if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Jan 31, 2011 | Kenmore Washing Machines
Hello! My Kenmore washer door will not open. It's completely locked and will not budge no matter what I've tried. I have a load of cloths in there as well. When I turned the power on detergent and cloths...
Unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). If the door still remains locked after a CCU reset, you can still open the door by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
NOTE: The "Fdl" and Fdu" fault codes are for older models of your washer, but the principle of accessing and releasing the door latch is still the same.
If your error code still persists, you may have to replace the door latch. Just follow the guidance in the link below:
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Dec 11, 2010 | Kenmore Elite 45986 Front Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
No Power and will not open.
Try unplugging the machine for 10 minutes. A lot of times the computer will reset and function normal. At least you can most likely get it to unlock to get your clothes off.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Reset computer
if unplugging and holding any button down for a few sec don't work without knowing why you need to "reset" can't help you if unit dead may be several things if buttons not working properly may be interface
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore H3T washer
The following link explains the "FH" error in detail:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
You may still have a water inlet problem if the washer is not filling and the taps are turned on.
If the door is locked and you cannot get the door open, you can use this link on how to access the manual release:
These problems may be attributed to a momentary glitch. Unplug the washer for 30 minutes and use the manual release to unlock the door. In many cases the problem(s) will clear. If the problems still persist, go to my profile and use the "Ask Me" feature for a quicker response to any questions you may have. I hope this helps you.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Stuck in cycle
unplug the unit. wait 30 secs. and repluge, youll have to restart cycle. but should work DO NOT add more soap
Mar 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
Washing Machines Logo
163 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
