Question about RCA D52W19 52" Rear Projection Television
Have blue flickering light.trying to locate skt's.to check soldiers joints where are they and how hard to access?
  • bubba Mar 24, 2008
    chassis # is ITC222 thanks
  • RCA Master
  • 8,617 Answers
Look on the back for the chassis number I should be able to tell you where you can get the service info for that model. But RCA has to be looked up by chassis number.
Posted on Mar 23, 2008
SOURCE:
I turn on my Hisense LCD TV and all I get is a black screen nothing happens except the blue light comes on.
This is the best video for the fix but, most non smart LCD HD TVs are the same. An old friend who was a retired police officer, had a CB Radio repair shop & he call the problem, "cold soldier joints" & CBs had PC boards w/ IC Chips, long before TVs did.
Dec 12, 2014 | Hisense Televison & Video
Why i have to wiggle the headphone jack to get sound
Two possibilities:
1) either the earbud plug has a loose connection, or
2) a soldier joint in the player itself is cracked.
Have you tried different earbuds? If that fixes the problem, then yea!
If new earbuds don't fix the problem, the it's likely a cracked soldier joint. Cracked joints are easy to repair, IF you have the right soldiering iron and are a careful working who enjoys learning new skills.
Good luck.
Sep 25, 2014 | SanDisk Sansa Clip MP3 Player
2000 GMC Yukon 4x4 lights aren't coming on
On 2001 I removed the control unit from the dash. I took the back off and found several soldier. Joints broken. After I soldier them it was fixed
Mar 14, 2014 | Cars & Trucks
My hotpoint hss25gfpjww will not cool or freeze the light inside is on so there is power
I would check the main board for signs of stress. i found a relay that had a loose solder joint on the compressor relay. After soldiering that she came to life. I had to remove the main board to do it. All of the connections are are not the same so you cannot screw up the re install. the main board is located in the rear of the machine under an access panel.
HSS SERVICE MANUAL
How it works
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 31, 2012 | Hotpoint HSS25GFP Side by Side...
Sunbrite tv 32 " 2 yrs old. Blue light comes on ,
Hello Joe Harlinski,
Welcome, and thank you for using FixYa!
To answer your question: Your television will have to be checked for bad (cold) soldier joints on the power supply board, as well as bad capacitors and resistors.A local Television Repair Professional should be able to handle this for you. If the board cannot be repaired, it can be replaced for roughly $75.00 to $95.00 plus the labor to install it.
Have a great day!
Nov 10, 2011 | SunBriteTV Televison & Video
It only lets me listen to music in one ear
  • If you have a warranty I would definitely send it back to the manufacturer. Most companies will pay for shipping for warranty repairs as well. What sounds like has happened happens a lot. The plug the jack plugs into (inside the Mp3 player) gets a cold soldier joint or the jack on the ear buds gets caught on something one to many times and breaks a soldier joint loose.
  • I usually open the media players and reheat the soldier joints myself. If you have already tried a different pair of ear buds it is almost certainly the jack inside the MP3.
  • Hope this helps.
Nov 08, 2011 | Nextar MA797 MP3 Player
I have a Roland keyboard with a DC jack. I can wiggle the jack and the power cuts on and off. How do I fix this?
  • Hi, I can help. You just have a cold soldier joint on the DC power input.Get the top/bottom off by removing a few screws and expose the connector. Just take a little soldier and touch up the solder points on the connector on the board. That's it. Will be good as new.
  • I recommend doing this before that jack gets pulled a bit to hard and tears off the circuit board which then may require more than a couple soldier joint touch ups.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 26, 2011 | Audio Players & Recorders
My son has a Handy Manny Flicker the Flashlight by Mattel. It appears that the bulb is burned out and I cannot seem to find how to replace it. Please Help!!!
The light bulb is soldiered in. However, if you unsolder the bulb you can order one off the internet and soldier it in. Pay close attention to which wire is soldiered to the bottom and which wire is soldiered more on the side of the light bulb. This is the only way to replace this light bulb.
Mar 23, 2011 | Mattel Handy manny fix it right motorcycle...
Bose wave radio has no volume. Everything working properly. Last time this happened, unplugged it for a couple of months and it worked again.
Most likely poor cracked soldier joints. check around the high heat ares drivers out put transistors amp ic ect... also check ground tabs. wave soldier results in thin joints. just reheat and ad more soldier. good luck!
Aug 31, 2010 | Bose Wave Radio
My t.v. flickers in and out of color, currently black and white.
U know how to soldier?Might need resoldier the video board pins joints.
Resoldier the yoke connection pins to the main board too.
If ur tv it in use for a long time would hurt to change the bulbs.
U have to soner or later.
Aug 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
