Question about Bosch 24 in. SHU42L05UC Stainless Steel Built-in Dishwasher
My dishwasher won't drain and water pools at the bottom of the dishwasher.
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 25, 2010
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Water collecting at the bottom of dishwasher, used it for the first time and there is a big pool of water at the bottom of the dishwasher when i open up the drawer
Your drain might be plugged. Check the bottom drain. If the water has no where to go, it will fill the bottom up. There might be a cap since it is new. It has to have a place to drain.
Feb 16, 2011 | Electrolux 23 in. ESL6114 Built-in...
The water is not draining at the end of the dry cycle. White dirty water pools in the bottom of the diswasher.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 02, 2011 | Dishwashers
The water is not emptying from the bottom of the machine..leaving a constant pool of water. help?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Is a small pool of water in bottom after dishwasher has finished
check the air gap for the blockage,or the underneath of the pump screen
Jul 31, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Standing water in the bottom
try starting any program - all start with drain. if it doesnt drain, suspect a foreign object in the drain pump
Mar 29, 2007 | Kenmore 24 in. 15074 Built-in Dishwasher
Bosch 24 in. SHU42L05UC Stainless Steel Built-in Dishwasher Logo
82 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
