Question about Ariens 34 In. Zoom Series Riding Mower
My Ariens tractor/mower won't start. I have replaced the battery, spark plug and starter. When I turn the key it gives a rapid ticking sound. What should I try to do next?
  • cwms9 Apr 24, 2010
    I have tried all of your suggestions and still receive the rapid ticking sound. I have replaced the starter, spark plug and battery. I was successfully operating the lawn mower on Tuesday and got off of it to move an object that was in my way. When I returned to continue it would not start back up.
  • cwms9 Apr 25, 2010
    Everything sounds logical but I am still unable to start. I have checked all cables and turned the motor by hand. I have also checked the connection of the seat switch. All seems ok. The rapid ticking is still comming from the starter but is getting weak now.
    I believe that if we tweak the right gadget the motor will start. I appreciate your suggestions. It almost sounds similar to when a car is having electrical problems. When I first replaced the battery it started then after a few hundred feet of cutting I got off to remove an obstacle then when I returned it would not start.
    Genius:
  • 1,016 Answers
Check all battery cables are tight. You will need to check that you are getting 12.5 volts to the small terminal on the starter solenoid, if you are then the starter is not engaging properly into the flywheel, turn the engine over by hand 1/4 of a turn and try it again.
Also check that your earth lead to the motor is tight.
You may need to fit a auxcillary relay to the ignition start circut if there is too much voltage drop to the starter solenoid.
If you need further information just let me know.
Thanks
Jason
Posted on Apr 25, 2010
  • Jason Maurirere
    Jason Maurirere Apr 25, 2010
    Ok, The rapid ticking sound you hear is it cominfg from the starter or a relay?
    If it is coming from the starter motor then it will be the solenoid, and the solenoid will do this if it is not getting enough voltage to engage the second part of the starter motor. A bit like when the battery is flat
    Check that voltage 12.5V at least is getting to the bottom solenoid cable.
    If it is not coming from the solenoid then it will be a relay.
    Check that your seat safety switch is ok and that the wires going to it have not rubbed through and shorting out on the body.
    Guru:
  • 722 Answers
Cwms9,
All starters have a solenoid, which should have 2-3 wires connected to it. One of these wires is the ignition wire.
1. Get to the starter and see that no wires are touching.
2. Check any and all fuses/relays.
3. If it's ticking, the starter (or solenoid) may be froze up.
4. Turn the key to the on position. With a small hammer (or tool) tap on the starter and then try starting again. If the starter is froze up (temporarily) the start may be getting to hot. This is usually caused by faulty wiring, in most cases a bad connection on a ground, or at the coil wire connection point(s).
5. Check all wiring and see that no wires are frayed, touching or melted. A melted wire could be the cause of a blown fuse, or two or more wires touching or mis-placed (wired wrong).
Also, make sure that the ground wire on the battery is secure at both ends, as well as the positive (which should go to the starter (the largest one). No other wires should to the to positive on the starter with the exception of the iginition wire, however these usually go on thier own threaded bolt on the starter.
If it continues to "tick" while trying to start and you are confident that all the wiring and connections are secure and as they should be, then you may need to replace the solenoid and/or starter.
Please let me know if this informations was helpful, and let me know if you need any further assistance with this matter.
Cordially,
carsandcomps,
Guru, Premium Expert @Fixya.com
Posted on Apr 24, 2010
  • 523 Answers
The rapid ticking sounds as if it may be the starter solenoid. You have mentioned that the ticking is less now, I expect this may be from the battery slowly using its charge. Is it possible for you to place a wire across the starter solenoid to see if you can bye-pass it? If your able to and it turns over then you have determined that it was/is the solenoid. I must agree with your note about sounding like a car; often when a solenoid is failing or the battery has alow charge (confirk your new battery does have a proper charge) the solenoid will tend just to click.
Thanks,
Tom
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Key just clicks the solenoid. bridging solenoid engages starter and turns over. new spark plugs.
Make sure the key is providing good power to the solenoid. If it is the the solenoid is bad.
Jul 31, 2016 | Ariens Garden
What could cause my engine not to start and just make a tick-tick-tick noise when I turn the key?
Sounds like the electronic fuel pump. Could have a bad starter or solenoid. If battery is good, could also be igniter box. Are you getting spark, if you are then probably not igniter.
May 19, 2014 | Husqvarna Garden
Mower will not start
Remove battery terminals and clean both posts and terminals
with sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to current flow both into and out of the battery. Have a load test done on the battery as mower batteries sulphate up from long periods of no use.
Jun 04, 2013 | Ariens 34 In. Zoom Series Riding Mower
2 year old Ariens tractor won't start
It could be anything from a carb issue to a spark plug or bad fuel.
May 24, 2012 | Ariens Garden
17.5 hp bolens lawn tractor motor turns slowlyand will not start. new battery, starter works. what is valve adjustment proceedure?
check the battery cable bypass them with jumper cables that engine uses a lot of amprich to spin it over valve adjustment would change all at once but i set mine to .006 when the opposite valve set the other one
May 11, 2012 | Ariens Garden
Im tryin to start it for the first time this year and it just wont turn over, making a clicking sound?....its a 42 in ariens lawn tractor
Hi and welcome to FixYa, I am Kelly
First try remving the spark plugs and pull the starter by hand. If you can not turn the engine spray WD-40 in the spark plug hole and let it sit several hours. After several hours try pulling it through again.
Just a note if you turn the engine through and get gas from the cylinder spark plug holes there is a carb problem. Should you note gas from plug holes... check the oil level to make sure the crankcase is not filled with gas.
If you can pull the engine through next try the starter again. If you still get the click without the starter engaging sucpect a battery problem. If you have a set of jumper cables jumper the battery and try again knowing you will have to ensure the seat switch is made to engage the starter.
If you can not jumper the battery... have the battery charged then try the starter again.
Still not working? Use a large screw driver and short across the 2 large solenoid terminals. Still just cliking... Suspect the brushes in the starter and or a dirty commutator on the armature of the starter.
Thanks for choosing FixYa,
Kelly
May 01, 2011 | Ariens Garden
Ariens tractor has new battery and won't turn over to start - what could be wrong?
couple things to check start by checking the starter itself then check the starter switch... good luck
Apr 03, 2010 | Ariens 34 In. Zoom Series Riding Mower
I had a problem with the battery about 1 month ago, I replaced the battery and it was working fine. I tried to start it today and the engine turns over but it wont start. After trying several times, the...
OF course if you keep turning the engine oner,the starter is going to get hot and start smoking.Its not the battery thats the problem,it sounds like you may have a carb problem or maybe just need a new spark plug
Jan 10, 2010 | Ariens 34 In. Zoom Series Riding Mower
Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
May 03, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
3,363 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
