Question about Maytag Bravos MTW6600T Top Load Washer
How do i remove the loose change trapped under the agitator ?
    Brigadier General:
  • 5,158 Answers
You'll need to remove the agitator to do that usually. fairly easy to do. the centre piece at the top unscrews (very often it will require you turning it the opposite way you would normally untighten something) remove that then lift it up. there is one other way but you need to be very lucky. some coins will react to a magnet. you may be able to get them out that way tho the whole basin is metal so not as likely.
Posted on Apr 24, 2010
3 Suggested Answers
outdoorsman5
  • 631 Answers
SOURCE: Item trapped under the agitator
Some of the washing machines you can buy a small inner tube and put it around the agitator and slide it under the agitator then blow up the inner tube and the agitator will come off.
Posted on Sep 09, 2009
  • 51 Answers
SOURCE: Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Posted on Mar 13, 2009
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
Where do you find the lint trap on the washer
google the make/model/manual possibly under neath at back tho some have a trap at the front
Mar 12, 2015 | Washing Machines
Removal of Agitator Maytag Centennial
here is a video on how to take it off
Feb 02, 2014 | Washing Machines
Kenmore Elite Top Loading Washer: sheet trapped under round base plate at bottom of agitator. How can it be released?
The link below provides the detailed instructions in removing the agitator to remove the item underneath. Click on the link.
Agitator Removal
Sep 05, 2011 | Washing Machines
Agitator loose does not swish clothes around .... can't figure out how to remove the agitator in order to see what may have come loosened or if splines are stripped .... how do you remove the agitator ?
Hello, on the style GE washer there is an agitator coupling under the agitator that will sometimes strip out. To repair this remove the agitator by pulling it straight up and out.
TIP: If you can't get your fingers under the agitator, you can slip a belt under the agitator and then pull by that, once the agitator is off you should see a yellow coupling held on by a 7/16 bolt, remove that bolt and pull the coupling up and off the transmission shaft. Sometimes it will be hard to remove and you might need to knock it up with a hammer. Once it is off you should be able to slide the new one back on, bolt it down and push the agitator back on.
Thanks
Jun 14, 2010 | GE WBSR3140DW Top Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sep 08, 2009 | Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Mar 13, 2009 | Washing Machines
Maytag Bravos MTW6600T Top Load Washer Logo
975 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
