Question about Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Zoom does not work since I dropped my lens
I Dropped my Tamron 28-300mm Lens for nikon and the zoom stopped working. The repair will cost upwards of $150, I can buy a new lens instead. Does anyone have a repair video - generic Tamron videos are good enough. Repair Manuals are welcome as well.
Ram
    Problem Solver:
  • 18 Answers
Not worth the effort - these are very complicated internal workings and even if you managed to disassemble the glass it would be difficult to know what is damaged without a 1:1 drawing of the internals of that specific piece of glass - plus you do not have a clean room - not trying to comment on your housekeeping but a dedicated clean room with a laminar flow work bench to keep out the FM you would add just by opening up said glass in a normal room - Pay the money if you love the glass - if not they make interesting and fun paperweights...
Posted on Apr 29, 2010
Want inexpensive 2x af teleconverter for d70 nikon lens 80-200 ed
You can order the Tamron 2x teleconverter here. Be aware that not all lenses are compatible with teleconverters, and you can actually damage some lenses by trying to use them with a teleconverter.
Jul 14, 2012 | Tamron 2x Auto Focus Teleconverter with...
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Sep 18, 2011 | Cameras
When I'm taking a picture, and i try to zoom, it zooms a little then stops, says lens error and goes black. If i turn it back on, it goes on, I just can't zoom.
Most digital cameras jams are the cost of lens problems while zooming, with Nikon Coolpix S4000, simply use your fingers carefully pulling on the lens while turning the camera on. this can be done by getting your fingernail under the lens opening and gently pull.muunlyte5608.jpg
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
Drop my Nikon D100 camera with a Tamron AF 75-300mm LD lens...lens will not extend, stuck on 200mm. If is worth repair, or can I repair it myself?
First question "is it worth repairing" if it were mine I'd look to see what a new one is worth then divide that in half (cause that's what you might be able to buy a used one for) then figure about $120.00 for cleaning lubricating and adjusting the your lens. With your lens you know what you have, buying used might need the service. you are the one to decide. As for the second question "can I repair it myself" short answer no. If you have to ask if you can repair it then you don't have the necessary tools and general knowledge of how to dismantle and reassemble the lens (and have it work when finished). The lens took a hit and most likely set the inner and outer lens barrels out of alignment causing the inner barrel to slip out of its seal and or focusing gear and hang things up forcing it will break parts causing more repair costs. All else fails get an estimate before repair. Been there with a lens myself and after a couple a months without bit the bullet and had it repaired. Cheers best of luck
Jan 28, 2011 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
I accidently dropped my nikon coolpix l18 camera when it was on. It just turned off and the lens is still open. I changed the batteries but can't turn it on.
You've damaged the lens. It costs at least $150 to repair, which is more than the camera cost. I advise you to buy a new camera because there is no way around it!
Sep 18, 2010 | Nikon COOLPIX L18 Digital Camera
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Aug 08, 2010 | Tamron 55-200mm f/4-5.6 Zoom Lens for...
Nikkor 18-200 mm VR with loose front ring and stuck zoom barrel
Unfortunately not. If the Nikon centre think it's been dropped, then you're stuck. They may well think so due to additional wear and damage caused as the initial fault progressed; this may well resemble the damage caused when a lens is dropped. You should really have sent it for repair as soon as the fault occurred.
All you can do is to write a letter of complaint to Nikon, asking them to intervene on your behalf with their authorised repair centre. It will help if you tell them how long you've been loyal to Nikon for and what other Nikon products you own; also state that if you must buy another lens that your money will instead go to one of their competitors instead and that when you replace your camera you will think hard before purchasing from Nikon again. It also helps if you tell them that you were well aware that you would be charged for any repairs caused by misuse, such as dropping your lens, and so would not have bothered to try and claim under warranty under such circumstances as it wasn't worth the risk of having to pay a big bill just to get a broken lens returned to you. Tell them that you have not dropped the lens and so you dispute their findings, and at the very least request that the lens is returned to you without charge so that you can get the lens examined by an independent repairer.
As long as your letter is polite, factual and states your argument clearly then you maximise your chances of getting them to revise their position to give you the benefit of any doubt.
Good luck.
Mar 09, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
I broke the top lens on my Tamron AF 70-200mm f/2.8 Di LD IF Macro Lens. I dropped it. Does anyone know how to order just the lens? I can replace it myself. Everything else on the lens is fine.
Contact Tamron USA via their web site or a phone call to get a price quote for the front lens assembly. However, I would strongly suggest that instead you allow Tamron to repair your lens since more than likely the internal roller glides have been compressed due to the impact. This would allow the front lens group to wobble a bit while focusing and zooming, and this would seriously affect the image quality.
Mar 15, 2009 | Cameras
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Tamron 28-300mm f/3.5-6.3 DI XR for Canon Logo
339 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
