Question about HP 2009M Monitor
When i turned on my monitor it stays on for a couple of seconds and goes blank (dark screen). But also has error message stating no DVI input?
I bet one of your capacitors are shot, there are several 22 pf capacitors that are connected to the high voltage transformers, that power up the LCD screen, check that first, capacitors that are burnt should be close to the two connectors that hook up the LCD monitor screen. hope this helps, there seems to be a problem with the 20 inch LCD flat screen monitors from HP, what a shame, poor quality products.
Posted on May 11, 2010
    Scholar:
  • 64 Answers
Here the solution to ur question.. made simple its from HP..
http://tinyurl.com/3xt5wwb
let me know if this was helpful regards, guru
Posted on May 05, 2010
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor going black
may you just uninstall the first video card driver & monitor driver, & then install it again..
please post back & let us know here, how things done..
Thank you
May 02, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
After Microsoft splash screen the monitor goes blank except for "no signal" messages if I turn off/on the monitor. I checked the monitor menu. Under Misc dropdown the Input is empty. Clicking input bring s...
Please check whether you are using a DVI (Digital Visual Interface) cable or VGA (Video Graphics Array) cable to the monitor.The monitor will adjust automatically to the requirements of the connected cable.From the question I think you had connected a DVI cable to the monitor.Make sure that there is no loose contact between the ports and the cable.Also make sure that the proper settings on the monitor are done for the DVI cable configuration.
Mar 07, 2010 | X2Gen MV20TP Monitor
Screen is black, No Input Signal
my older monitor had a similar problem but instead of black its bright white and it keeps auto adjusting but not right it goes off screen. i still use it just not as a main monitor as it is old. erm see if its it warranty if it isnt then you probably need to get a new one
Jun 09, 2009 | HP W2007 LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP 2009M Monitor Logo
149 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
