Question about Diehl TIME CLOCK- 120V 24 HOUR
Diehl Spa Timer
The first part has number 18802-024 24 hr timer
the second 18801-024 7 day timer
I am trying to match this with current part and can find no information.
  • 27 Answers
Http://www.swimmingpoolsetc.com/sbb-3-40-0009.htm
P.S: I was just looking for this and stumbled across it myself...
Posted on Dec 12, 2010
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Jan 03, 2014 | Weathermatic ProLine PL1600 Outdoor/Indoor...
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
I have a holiday timer LW28080. Following instructions to the letter the unit did not go on at the set time. The manual works but not the timer. Does the time actually have to start on the first day...
LW28080 is NCC brand digital power center.
Copy following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#0050024
Programming should start on the day you selected for Program 1 ON. So if Tues was selected, timer should start Tuesday.
Use paper clip, and push in Reset button for 2 seconds. Repeat. Always reset digital timers before programming to clear memory glitches.
Plug timer in for 10 minutes to charge battery.
Be sure to set current time with correct day, hour am-pm and minute.
Each ON program requires OFF program
Set program 1 ON and then set program 1 OFF.
Make sure selected day(s) of operation match for both ON and OFF settings.
Check am-pm conflicts in programming.
Avoid 12:00, to avoid am-pm confusion. Use 12:01 or 11:59
Avoid programming overlaps and conflicts that cause timer not to function as expected.
When programming is finished, press current time button to return to current time.
It appears timer is ready for programmed operation at this point.
Install Mi-MH battery that comes with timer.
Do not exceed watt rating.
This timer comes with 1 year limited warranty and can be expected to last 1 or 2 seasons, and probably quit season 3.
1-800-730-3707
Nov 24, 2012 | House Brand Hardware & Accessories
New 9v battery installed. Current hr. set. +or- would not change day. Now only a blank screen. Help!
Copy following link to identify timer, and download possible manual:
Otherwise timer is unknown, and cause for failure unknown.
Offhand, I cannot think of any timer with 9 volt battery
Add a comment and educate us by describing product you are using.
Nov 12, 2012 | Hardware & Accessories
What is name of srew on timer dial that trip switch .
It's called a tripper.
Question posted under Paragon 4000 series timer that uses X2772 tripper.
Paragon is no longer making that timer or tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
If different timer is needed, use Intermatic crossover to match timer number:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Sep 01, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Vigoro 196-036 water timer manual -- need instructions on how to set timer for the Vigoor 196-036
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Jun 12, 2011 | Hardware & Accessories
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Pointer "B" was moved, contrary
The link above shows all the Paragon timers.
If you have the Paragon 4000 mechanical timer, then the pointer is at the 8:00 position.
To set current time, you lift and rotate white dial until current time lines up with the 8:00 position
If this is not your timer, then add a comment with your timer and model number and I'll look it up.
Nov 06, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
My 99 Pontiac Grand Am's radio is on Loc. I have the 2 codes but I don't know what to do now?
turn ignition switch ON but leave stereo OFF---press MN button and OOO should appear -----press HR button to make the last two numbers match your code then release button ---press hr button until the first one or two numbers match ur code ----press AM/FM SEC should appear indicating the radio is unlocked if LOC shows up either took longer than 15 seconds between entering codes or wrong code entered --u r allowed only 8 tries after that radio becomes INOP and dealer is only one able to reset
Jan 21, 2010 | 1999 Pontiac Grand Am GT
Diehl  TIME CLOCK- 120V 24 HOUR Logo
459 people viewed this question
Top Diehl Hardware & Accessories Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Gene Haynes
Are you a Diehl Hardware and Accessory Expert? Answer questions, earn points and help others
