Question about Cross AS1512X Shredder
When I push the button to AUTO the REV light and AUTO light come on simultaneously and nothing happens. The motor does not come on and the machine makes no sound.
  • 3,866 Answers
9 times out of ten you got a bad motor.
what you can do is try applying power to the motor bypass the switch if the motor turns then the switch is bad do not shoot the messenger here just try testing the motor or switch with the methods i said.
Thanks
please do click the accept button for my efforts.
Posted on Apr 24, 2010
When I plug in the machine all of the lights just flash and nothing else happens
unplug unit and throughly clean unit, especially the bar code reader window. Take apart the piercing nipple assembly and make sure it is not clogged either. Use the cleaning disk and descale the unit quarterly as this prevents build ups in the brewing system
Apr 07, 2014 | Braun Tassimo Espresso Machine/Coffee...
Control locked red light is on so nothing I can do to power it up and use. I turned the breaker off and on but nothing happened. What can I do to fix this?
If you are holding in Auto Dry Level for 3-4 seconds this should unlock the controls. If not, this usually indicates a stuck button on the control panel. Feel the push-in action of the Auto Dry Level button to see if it feels stuck or hanging up in any way. If the button feels right then this indicates that the user interface (touchpad) is at fault.
Oct 20, 2012 | Kenmore 6.7 cu. ft. Electric Dryer
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
When button is pushed the light comes on then when the start/stop button is pushed the machine makes a noise for a few seconds then stops and nothing else happens.
hi,bill take the back see if the belt may have snapped if ok the other fault could be brushes on the motor also check the pump for blockages hope it helps
regards
shaun
Nov 10, 2011 | Washing Machines
Won't power on
When in the "auto" position the machine then needs you to insert the paper to make it run....if this dosn't happen then the "eyes" may be dirty/dusty....try cleaning them or you may have lost the pcb inside the machine... you can call Royal at 1-800-524-0799 for parts advice.
Mar 27, 2010 | Royal Office Equipment & Supplies
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Control panel lights
The manual indicates this means that it is time to decalcify the machine.  After doing so, press the ON/OFF and PROG buttons at the same time for 2 seconds.   Jeff, Burbank CA
Dec 11, 2006 | DeLonghi CAFE DUO Dual Drip Coffee Maker
32 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
gbob59
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
