Question about LeapFrog Clickstart My First Computer
Mouse not responding
Mouse has been slugishly working. We tried changing surface we were using the mouse on, no change. We changed the batteries, no change. We opened the cover for the mouse plug into the keyboard and made sure it was securely plugged in now not working at all. We turned it off and on. Still nothing, mouse not responding at all. Suggestions?
    Problem Solver:
  • 6 Answers
Not a real suggestion for solving your mouse problem but you can
use Mousk until your mouse problem is fixed. www.channels.nl/mousk
Posted on May 02, 2010
Logik LMWLPP13
I would still try changing the battery. Even if the light in the mouse is still visible, the battery voltage may have dropped.
Feb 26, 2014 | Computers & Internet
I took the batteries out and replaced them, now the mouse will not respond. It is an HP PIN 5188-6926
If it worked before you changed the batteries, it should work after changing the batteries.
  • Are they inserted correctly ?
  • Are they new / fresh batteries ?
  • Did you turn the mouse "on" ?
  • Try rebooting you system if the above checks out, so that your system can recognize your mouse
Mar 21, 2011 | HP Wireless Optical Mouse
I plug in the link for the mouse and it gose green. the mouse itself stays blank, no red light, and when i try to use the mouse it dose not work.
try changing the batteries
if that does not work,try using the mouse near the sensor
if still doent work,hit the reset button at the bottom,remove the batteries for a couple of minutes,put it back in then use your mouse on a different surface
Feb 13, 2011 | Microsoft Wireless Notebook Optical Mouse...
The pointer on my wireless mouse is not working. I just changed the batteries.
use the mouse near the comp.the range of the mouse from its sensor matters.if it still doent work try using the mouse on a different surface
Feb 09, 2011 | Toshiba Wireless Mouse PA3205U-1ETC
I disconnected my wireless mouse and used another microsoft wireless mouse and signal output while on vacation. Now my wireless mouse is slugish and sporatic and I need to push the button on the output to...
Did you leave it on--maybe the batteries are dead or maybe subconsciously your hand likes the other mouse better? Nonetheless, I'd re-introduce or resynch the mouse and antannae (changing the batteries might not hurt either). Also, if they are similar, make sure that your computer isn't trying to use the other mouse driver to run your primary mouse (depending on your OS, the default mouse should show-up in your Control Panel--hardware devices and make sure that it correlates to the one that you want). Good luck & I hope this works.
Feb 23, 2010 | Microsoft Wireless Laser Desktop 4000...
New cordless mouse slow to respond to "click": cannot control or direct movement: jerky, sporadic. Is this because I do not use a mouse pad?
mouse pad would help but you may have a virus so go to windows help and support and download the windows defender and run it, there have been a lot of bugs affecting mice lately however do try to use something that has a surface on it that would make the mouse work better if it does work better then buy a mouse pad next if it's still slow you can go to control panel and sped up the mouse and also into tools Internet connections and change the mouse properties there.
Feb 05, 2010 | Logitech Cordless Mouse
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 05, 2009 | Computers & Internet
yes there is a battery in the mouse, it depends on how often do you use the pc to change the battery
Mar 23, 2008 | Logitech Cordless Desktop EX110
Wireless mouse quits working after a few seconds
Did you replace the batteries? This sounds like it may be the problem. A year is a lomg time for batteries depending on how often you use the computer.
After changing the batteries, you may have to do this:
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Sep 03, 2006 | Dell Wireless Keyboard Optical Mouse w0147
LeapFrog Clickstart My First Computer Logo
504 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
