Question about Canon PIXMA iP1600 Printer
My canon says remove paper jam but there's no paper in the printer
  • 4,041 Answers
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
  • Clive
    Clive Apr 25, 2010
    Hello there
    You may not see a paper jam.
    This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
    Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
    And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
    Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
    That is where you'll find the print head assembly parked on top of it.
    It also has an electrical pump to milk the print heads and test for ink flow.
    So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
  • mallswang Nov 21, 2010
    Putting a piece of card stock through the printer did the trick. Out came a grape seed! Thank you!
How do I fix a canon mp190 series with a papper jam, I have removed all the paper?
Restart your printer.if then even your canon printer is showing paper jam.
  1. Open the paper output cover. ...
  2. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  3. Hold the jammed paper with your hands.
  4. Pull the paper slowly not to tear it, then pull the paper out.
Get any kind of canon printer troubleshooting call us :+1-866-641-8283
CANON PRINTER TROUBLESHOOTING
Apr 19, 2018 | Canon Office Equipment & Supplies
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
My Canon MF4010 printer shows "paper jam" even i have already removed paper
the paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 28, 2010 | Office Equipment & Supplies
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon PIXMA iP1600 Printer Logo
352 people viewed this question
old marine
old marine
