Question about Canon Office Equipment & Supplies
I have a Cannon Multi Pass MP730 Printer. I have an alarm flashing on the screen that says Wrong Cartridge even though I have all correct Cannon cartridges in the printer. I have loaded them several times and still it won't shut off is there a way to shut this off?
  • 1 more comment
  • jburnside Apr 24, 2010
    I have a Cannon Multi Pass MP730 Printer. I have an alarm flashing on the screen that says Wrong Cartridge I just tried removing and cleaning the print head and have loaded them and restarted the printer and it still says Wrong Cartridge. I have loaded them several times and still it won't shut off is there a way to shut this off?
    Thanks very much I tried your solution and it is still saying Wrong Cartridge.
    The cartridges are all correct, so I will contact Cannon.
    Regards,
    Janet
    No solutions didn't work I am going to have to contact Cannon.
    Thanks for trying
  • 1,606 Answers
Unplug the printer from the power, remove the 4 ink tank/cartridges.
Wait for a few minutes then plug the printer back in but do not insert the tanks.
That error is telling you that you have one of the cartridges in the wrong place or the cartridge is meant for a differant model. Check the label on the front bottom of the carrier it should show you the correct location. If this is the case then you may need to run a few clean cycles or put up with some funny colors for a while if the wrong ink was instroduced into the system. Won't hurt anything but will make for incorrect colors during printing.
Double check the cartrdige numbers for you machine they should be
a BCI-3eBk (black) a BCI-3eC (Cyan), a BCI-3eM (Magenta) and a BCI-3eY (Yellow)
Sometimes you can have one cartridge not inserted correctly and this will also cause this error. It may be in the right place but just not seated.
If this doesn't clear the error you need to contact Canon support as you may have a problem with the print head assembly. Just go to www.canon.com click on support and then chose support by phone or email. They will be able to tell you if the 730 requires a trip to the repair depot.
Posted on Apr 24, 2010
    President:
  • 2,923 Answers
Removed the ink tanks and the print head. The print head area was all gonked up with ink as well as the flanges the print head sits on (still in the printer). DO NOT dunk the print head in water.
The refill ink package comes with printhead and cartridge cleaner -- smells like alcohol, but who knows. Use that and a combination of Q-tips and kleenex to clean any ink away from the print head and nearby surfaces. Drip some cleaner into the print head holes the ink tanks plug into and then dried off the whole print head assembly.
Follow the steps below:
1. Put the cartridges-leaver up and removed the 4 ink-cartridges.
2. Remove the print-head which is not screwed or hard-attached so all you have to do is carefully take it out of its place (I suggest directing a strong light to this area to understand the parts beeing touching).
3. once outside, the print-head had no ink on the black-cartridge touching area which i believe due to a problem in the black-ink cartridge, since all the other 3 contact areas had a good amount of ink. I assumed that the black-cartridge was not delivering ink which leads to the machine error and forced by hand some black-ink to this area and replacing the black-cartrige by a new one.
4. Put everything back together and turn it on. The printer will cycle itself, remove the "wrong cartridge" message and stood ready for me to print. Finish.
Thank you and good luck!
I have a Canon MultiPass MP730 that is flashing the Alarm and reads cartridge jammed. However I can move the cartridge manually. The machine won't do anything because of the alarm. How do I fix this?...
To fix this you first need to remove the ink and the print head.
Wash the 4 ink pads in luke warm water.
Keep running the water over the bottom of the print head until the water shows no sign of ink colouration.
Make sure all of the print head is completely dry before replacing it into your printer.
After restarting your printer you will probably see the alarm light still flashing.
Now hold your finger on the resume button for up to 2 minutes or until you hear a clunking sound.
Hold your finger on this button and the printer will fix itself and the alarm light will stop.
Aug 30, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
WRONG CARTRIDGE
Press the reset button if they can correct that problem. Maybe you can used the not genuine cartridge on your printer or it could be not properly inserted your cartridge. Try to power off the printer and check your cartridge then power on it again.
May 29, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Printer will not print
Hi, you can try to remove the cartridge and try cleaning the contact switch on both printer side and cartridge side.
Jan 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
"Wrong Cartridge"...alarm still flashing
you have the wrong cartridge type in the printer or you have it in incorrectly , i would need the name of the printer and the name/number on the cartridge to tell you which it is, but it's one of the two
Apr 20, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Wrong Cartridge
replace print head. print head is bad.
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Wrong cartridge error message.
You need to replace the printhead (QY6-0064-000). It costs me around $50 in the U.S. But now, it works just fine. indogirl
Apr 01, 2007 | Canon SmartBase MP730 All-In-One InkJet...
old marine
old marine
