Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint wt741 how do i get to the filter
    President:
  • 1,294 Answers
In most machines the filter is located under the panel in the bottom of the machine (the panel under the front door).
If u have manual refer; pull the panel out and you will find the filter there.
Before you open the filter keep a bowl & cloth to collect much water.
Posted on Apr 03, 2008
4 Suggested Answers
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
  • 100 Answers
SOURCE: Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Posted on Jan 28, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint wt741 fault code f08
You need to check all the connections to the pressure switch the heater and the module as generally speaking it is due to a bad connection, you shoul not need to disconnect anything.
Hope this helps.
Posted on Jan 16, 2010
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 shakes violently
Washers utilize spring loaded legs for self-balancing or threaded screw in feet that uses a manual locking nut.
If unit is level and sitting solid on the floor,you may have a stabilizer issue or a weak wooden floor.
Nov 26, 2017 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT741
Apr 20, 2008 | Hotpoint Aquarius WD640 Front Load...
Leaking wt741
This is a European Model mostly sold in the UK for about $250 pound I cant find any books or manuals on this model you might want to check some UK websites
Jan 24, 2008 | Washing Machines
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
211 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
